From
the Scope Live Bar menu, select 'Set / Settings' (see
left).
The
Program Settings window will popup (see right).
Select
the 'Enable VST Integration Mode (XTC)' checkbox.
Close
Scope. Note Scope must be closed for XTC mode to activate.
Start
up Cubase.
If
this is the first time you have used XTC then you need to update
your plug-in information, otherwise skip this step.
From
the Cubase main menu, select 'Devices / Plug-in
Information'. The 'Plug-in Information' window will open.
Press
the 'Update' button and wait a few minutes.
Ignore this message if you had an
older version of Scope on your PC.
From
the Cubase main menu, select 'Devices / VST Connections'. The
'VST Connections' window will open (see left).
Select
the 'Inputs' tab. By default, one Scope input will already
be present.
Right click
and select 'Add Buss / Stereo'. The next Scope input will
be added to the list. Repeat for all inputs.
Rename the
input busses if desired by overtyping the Bus Names (see right).
Select
the 'Output' tab of the VST Connections window. By default, one Scope
output will already
be present.
Right click
and select 'Add Buss / Stereo'. The next Scope output will
be added to the list. Repeat for all outputs.
Rename the
output busses if desired by over-typing the Bus Names (see right).
- You may change the individual ports by
right clicking on any of the 'Device Ports'. A popup
selection window will appear for this purpose (see right).
TIPS FROM KWILD ON HOW TO MAKE XTC WORK IN SCOPE 5 |
- Go to /App/Bin and open
cset.ini , change XTCMode=0 to 1.
Under [SEQPATH]
add the folder you have put the .dll's for your vst host (example
c:\VSTPLUGINS\XTC)
So it will be :
[SEQPATH]
Path1=C:\VSTPLUGIN/XTC
- Create a folder /DEVICEXTC into
/SCOPE PCI installation path and put all the .dev and .mdl you want
to use as XTC.
- Go to your old SFP4
installation App/Bin take SCOPEVST.CFG and copy to the folder /SCOPE
PCI/App/Bin
- Edit SCOPEVST.CFG and point to
/SCOPE PCI/DEVICEXTC and subfolders , example :
ScopeMono C:/SCOPE PCI/DevicesXTC/Mono/*.* (if u wanna put mono
effects into /Mono)
ScopeStereo C:/SCOPE PCI/DevicesXTC/Effects/*.dev (if u wanna put
effects into /Effects)
ScopeSynth C:/SCOPE PCI/DevicesXTC/SYNTH/*.* (if u wanna put Synths
into /SYNTH)
- Go to the folder where you have
the XTC .dll's for your VST HOST (Ex. C:\VSTPLUGIN\XTC) and edit
XTC.INI to point into /SCOPE PCI :
[SCOPE]
Application=C:/SCOPE PCI/App/XTCAPP/XTC.pro
Bin=C:/SCOPE PCI/APP/BIN
Config=XTC-Config
Create the .dll's for the devices you wanna use as XTC and put it
into C:\VSTPLUGINS\XTC.
Dante and KWILD October 2010
For more advanced configuration information check the PlanetZ XTC
Patch Guide |
