Remember to Open Cubase after
setting up your Scope project, but before opening Record or
reason.
Select 'Devices / Setup' from the main menu.
From the left hand devices list, select 'VST Audio System.
In
the VST Audio System dropdown to the right, select 'ASIO
SCOPE'.
Select
the 'OK' push button.
- In Cubase, select
'Devices / VST Connections'
Select the 'Inputs' tab. There should be already one
input bus showing by default.
Press the 'Add Bus' button and select 'stereo' to add a
stereo input bus.
Rename the first bus 'Scope In'.
Rename the second bus 'Mix In' .
- In Cubase, select
Select the 'Outputs' tab. There should be already one
output bus showing by default.
stereo output bus.
Repeat this step 15 times.
Rename each output bus to correspond to the names you gave
the STM Mixer channels.
