- Select 'Create / Combinator'
from the Reason / Record main menu. A Combinator will
be added to the Reason / Record Rack.
- Right click on the Combinator and
select 'Create / NN-XT Advanced Sampler' from the context
menu.
Select a Brass patch for the
NN-XT.
Label both the NN-XT and Mix
Channel 'Brass 1'.
Repeat the procedure until you
have built up a large number of Brass samples each with a
Mix Channel routing them to the SLL mixer.
- Press the TAB key whilst the Record project
has the keyboard focus. The rack will flip to
reveal the connections at the rear of the devices.
Connect the left and
right outputs of the Master Section (representing
the SSL mixer) to the Record Hardware Interface
Audio Outputs 1 and 2.
Ensure that each of the
Brass loaded NN-XT samplers is connected to a Mix
Channel. The Mix Channel devices represent a
connection feeding into Record's SSL mixer.
From the Reason Project, select
'View/Main Mixer' from the Record main menu.
Solo the Brass section on the
STM2448 mixer whilst playing back the Cubase sequence.
Make mix adjustments to suite
using the SSL mixer. Adjust volumes and pan alternate
channels hard left and right to achieve a large stereo
spread.
