Dante:
So what is 'Dynamic Parametric' processing?
Sonolive: We have been working a very long time on this kind of
equalization, and we think it's the most musical way of equalizing. As if
it was to be a proven concept, we found many famous manufacturers had issued
similar devices (both hardware and software) around the same time we
released DynPara.
Dante: So what is the philosophy behind Dynamic Parametric
processing?
Sonolive:
It
can be understand as the mixing of two technologies that do not act on the
same characteristic of an audio signal:
Frequency : frequency domain - it is an Equalizer.
- Level
: dynamic domain : it is a Compressor.
Dante: So how does it work?
Sonolive:
Let's first
talk about a standard parametric EQ. When one (or more) frequencies
contained in an audio signal is not at it's right level (too much or too
less), then what do we do? We boost or cut it, that means we increase or
decrease its level, whatever the level of this frequency is. We have got
some sets of parameters to achieve this:
- FREQ
pot that adjust the frequency on which we want to work.
- Q (quality factor) that acts on the width of the frequency band around the
centered frequency determined by FREQ.
- GAIN Pot : that is used to increase or decrease the level of this given
frequency.
This is how things work on a standard parametric EQ.
Dante: Ok, so what is so different about a Dynamic Parametric EQ?
Sonolive:
The big
difference is that you cut or boost the level of the desired frequency only
when needed. This is achieved with a dynamic section for gain control
instead of a single gain pot. The level of the defined frequency is
controlled not only with a gain pot but a set of controllers similar to
those on a compressor. So we have:
- FREQ
Pot (the same as on a Parametric Equalizer)
- Q Pot (the same as on a Parametric Equalizer)
- A set of dynamic controls: THRESHOLD, RATIO, ATTACK AND RELEASE that acts
on the level of the centered frequency.
At this point, we can see that the level of the centered frequency is not
affect all the time (whatever its original level is), but it is cut or boost
only when needed and musical signals are full of situations where this can
be very
useful.
Dante: Can you give us an example?
Sonolive: Sure. Let's say you have a vocal and you want
to try and suppress an aggressive frequency that appears when a singer begins to
shout. Let's take as an example one of my friends, a singer with a
sweet warm voice when he sings quietly. Fantastic every thing is ok. But
here it comes, he begins to shout! At that point I can hear a very
disagreeable 4OOO Hz that appears in his voice. So what do I do? With a
standard parametric equalizer, I would set the frequency on 4K, adjust the Q and cut
this 4K to -4 dB. Cool...it works. A few measure later his voice calms
down. Damn I miss this 4K that made his voice so sweet. What do I do? I
boost the gain to 0 dB?
Dante: No, because then the whole process could now take
too long, if you have to ride the equalizer controls from beginning to end by trial
and error.
Sonolive:
Exactly, that's were we use the Dynamic Parametric Equalizer. In this example,
I set the frequency on 4K, adjust the Q and look for the good
threshold/ratio/attack/release settings in order to adjust this frequency
only when he shouts. Fantastic, here it is and it works all time.
All
along this song!!!
That is why we (and many others) think that Dynamic Parametric Equalizer is
the most musical way of equalizing. And not only does it work
signals such as drums, bass, guitar etc but it also works very well on more complex
signals such as those mixed as sub groups.
Dante: Could you achieve a similar result using a Multiband
Compressor?
Sonolive:
Possibly it
may work but it's not as easy to set up. To achieve 4 dynamic parametric
bands, you would need a 9 bands compressor.
