GaryB: Some
			general tips for setting up your computer to work with Scope
			hardware.
As in the letter that came with v5.1, in the  BIOS (you may
			have already done this) disable any of these things or anything that
			is obviously the same but slightly differently named:
				Intel EIST
				Intel C State
				C1E Support
				Overspeed Protection
				Hyperthreading
				Execute Bit Support
				Set Limit CPUID MaxVal to 3 (maybe not so important)
				Intel Virtual Tech
				Intel VT-d Tech
AMD processors also have speed stepping called 'power now' or 'cool
			n quiet' or something similar, which MUST be disabled.
Go to:
			Start\Programs\Accessories\System Tools\System
			Information\Conflicts/Sharing and tell me what (if anything) is
			sharing an IRQ with Scope hardware.
In Windows 7:
				Go to Start\Control Panel\Power Options then click on 'Change Power Settings' and make sure that sleep is set to 'never'.
- Click on 'Change Advanced Settings' then open 'PCI Express' and turn off 'Link State Power Management' (especially good for XITEs). I like to set the minimum and maximum level for the CPU at 100%.
- Confirm the above changes.
The reason for the bios changes and the power changes is to insure
			the the CPU is always 100% on.  Real-time audio does not have time for
			the power to the CPU to ramp up, as Windows believes the software
			requires.
For the PCI cards, I would go to the device manager
				and disable the 'reset board if idle' option.
- In Windows XP it's in the Start\Control Panel\System\Hardware tab.
- In Windows 7 go to Start/Right click on computer and choose 'properties'.
- Click on the device manager and find the Scope hardware and choose 'properties'.
- Uncheck 'reset board if idle'.
That way if you leave the computer
			unattended for an hour or two, Windows won't decide to cut power and
			make you have to restart Scope and reload DSPs.
There are actually a number of ways to get to these settings.
			If you already have a way you like, use it.  Now a tip to get
					rid of some of the fancy graphics:
- You can click on the 'Advanced' tab in Windows XP or Advanced System Settings and then the 'Advanced' tab in Windows 7.
- Push the performance 'Settings' button and choose 'Adjust for Best Performance'.
This will give you plain Windows 98-type windows, but it will save a TON of overhead that the fancy Windows graphics waste.
