krizrox:
Well,
I've had a chance to use the PSY-Q on a
couple of mixes. I have to tell ya, this is a nice tool to have. It came
out just at the right time for me since I'm in the process of mixing and
mastering a recording project for a local rock band. This is a
great tool if you have a rather dull sounding mix (would be great on
some old analog cassette tape restoration I'll bet). I've been using it
primarily on some vocal tracks and it's worked great! It really adds
some nice - smooth sounding - sparkle. It can make a track sit in the
mix a little better. I didn't notice much of a difference on the bass
tracks. This thing is clearly happiest with a mid-range or full-range
signal. If your overall mix is already tight and bright sounding,
you probably don't need this. But if the mix or track seems a little
dull and lifeless, this will work wonders. Since I prefer to use things
like this sparingly, I will probably pull it out only for individual
tracks that seem to need a little spice. The vocalist I'm working with
at the moment has kind of a lazy monotone-ish quality to his voice. It
fits the music OK but sounded kind of dull. The
PSY-Q changed that instantly. Janni: I use PsyQ and bx_digital to fatten up the stereo image and avoid phase issues. If you use other techniques you might have to check mono compatibility. | ||||||
Sonic Core: PSY Q is a powerful but easy to use tool for sound optimization. Behind the unassuming surface lurks a professional psychoacoustic equalizer with an integrated stereo expander, a bass compressor and a Soft-Clip unit. The components are finely tuned to one another and function as an 'intelligent' ensemble: that is, the PSY Q continually analyzes the incoming signal and reacts to it by performing complex phase and frequency response manipulations. The result: the sound material is altered in a way which is pleasing for the human ear. Bass tones are given additional impact and loudness, high frequencies have increased shimmer and "airiness" and the complete mix becomes more transparent and defined. PSY Q simply makes things sound good. | ||||||
