Bud Weiser: Original Minimoog D has not many options modulating the (dual-) VCA, except by the internal VCA envelope or you're using an external modulation source and feed the rear panel VCA CV-input jack. In fact that's where one of my MOOG 1120 CV pedals is connected. Now, Minimax originally doesn't exist in a modular design. DJMicron made one http://forums.planetz.com/viewtopic.php?f=16&t=31095 but it also doesn't have additional CV inputs. So the closest to VCA amplitude modulation is using OSC #3 "lo" (=LFO) on the filter (filter modulation rocker switch set to ON). Minimax has more options than a original Minimoog D and now I cannot remember if there are ways using the MIDI CCs or not.
MiniMax does some other things a real Minimoog can't, as well as the effects
and polyphony. Much more important, there's
scalable velocity sensitivity on
filter and amp in Minimax similar to the Studio Electronics Midimini
(rackmount). On MiniMax I wish we had soft and hard sync and an
additional LFO just only for the wheel / vibrato and have OSC #3 free
for more modulations. If I remember correctly, there was also a PW-modulation
modification available. Regards the mod wheel on the Minimax there
ARE
controls for "MW-Intensity" and "MW
offset". Surprisingly,
there are also "CV controls" related to the original pack panel
inputs of a hardware Minimoog D for OSCs / VCF and VCA. And when I
clicked on these virtual pots, it opened the MIDI CC window, hurray !
So, in theory, it should be possible to create a MIDI signal to generate VCA
amplitude modulation and feed it into Minimax. Automation curves in a
sequencer or 'MIDI LFO' comes in mind.
I also
noodled around with Minimax and Celmo's 'Guitar Blues Amp Stereo' (there's
also a mono version) until I found out how to store new presets permanently.
I get the slight amount of crunch out of that amp emulation which gives
Minimax the vintage kick. In try to emulate my Jan Hammer type leads that
way and with some sounds it works. I also tried the amp with
B2003 and Leslie stopped. Not bad for the vintage Brian Auger type
sound. | ||||||
