sx and windows hanging
Antec 550 Neo HE
http://www.antec.com/ec/fr/pro_powerSupply.html
_______________________________________
our music at http://algufr.bandcamp.com
and at http://alg95.bandcamp.com
more music at http://hurpasard.free.fr/index_en.html
No the problem is not solved.
But i think with all the clean install and tweaking I've got a more stable system.
My last tests show clearly a problem with this sts5000. Same Cubase file - SFP project with the only difference : sts5000 or B2003
sts5000 always ends up with hanging up windows.
b2003 is running without end, no way to bug it down. In the end I tried heavy editing while playing - stable.
whats so different in the sts5000 ?
since this post, I worked with projetc where I removed the sts. I had no windows hanging until now, and this time it came when looping around a bass - drum thing and playing a long solo on my midi keyboard that is connected to the pulsar midi in port => cubase => back to sfp into the pro-12.On 2006-08-13 10:57, Shroomz wrote:
Take it one step at a time would be my advise. Don't connect up lots of midi gear until you've got a clear picture of what may be the problem. For example, if you suspect STS to be the problem, I'd do some serious testing without STS involved. If you have no problems until adding STS into the picture, then you'll have found the source, if not, you'll have eliminated a possible suspect.
so the problem is not solved, is not limited to the sts - do you have any suggestions of what i can trie ?
Asus p5wd-2premium mobo ???.
It's still problems here with the STSs which i can not miss in my scope settings,
without the STS it's working fine,
My problems still on board.
some days ago these was some reactions:
ali
Pulsar Geek
Hi Ali why is it so difficult to have contact with Andre ?
I think his advice for the Asus p5wd2-e premium is more of COMPROMISED to Creamware products,sts crushies all the time.
He's also not available just to inform his customers about complains base on his recommendation.what exactly is the reason & he's advice on his configurations both hardware & the BIOS may be might help.
okantah
http://www.planetz.com/forums/viewtopic ... forum=1&24
Posted: 2006-08-18 14:16
okantah, contact andre and ask how he has his system configured.
Also check out this link by Marc de Ruiter
he got the same mainboard
http://www.planetz.com/forums/viewtopic ... orum=19&16
[ This Message was edited by: ali on 2006-08-18 14:16 ]
ali
Pulsar Geek
okantah
hello Ali,
When clicking on the last 2 links - I get a blank page with the only text : Hacking attempt!
I agree with okantah that the help of Andre would really be appreciated
Hi gustav
i have recieved your post last time but my internet line was disconnected due to delay payment,it's back today.i would look for time to reply you soon please forgive me!
My system work 100% now since i did the pc.stardard installation 2weeks ago,no no nothing else negetive.
The asus wd2-e premium maybe works only on pc.stardard installation .
gustav i would get to you soon.
Thanks a lot to all planetz contributors.
Espectially thanx to Ralf for his post,
okantah
cheers
okantah
cheers
