Huge acoustic drumkit, free for planet-z
ok, here it is:
filtering: the idea is to give a sample a 'natural' dynamic response which emulates how it happens in the real world. The general rule is: as we lower the dynamic of a sound, the high harmonics content decreases accordingly. Which means that we want to gradually increase the filtering as the velocity decreases. Now, with multiple layers, this technique can be applied to hide the velocity 'jump' between different samples from the same drum, or whatever instrument.
The thing is, let's say we have 3 drum hits from the same instrument: p, mf, ff. Let's say that these samples are assigned to those arbitrary velocities: p: vel. 0 to 60, mf: 61 to 100, ff 101 to 127. The (low pass) filtering would gradually decrease the harmonic content of the ff sample, with the velocity as a modulation source, until it reaches the velocity split, where the ff sample should ressemble as much as possible to the mf sample.
I'm not sure if and exactly how this can be achieved on various samplers. The only sampler I know of which you can program to filter from value y to value x is kontakt, but I'm sure there are workarounds to do it elsewhere.
The same principle should be applied to the attack of a sound, as the attack's shape is less steep as a sound is played softer.
More later...
More later...
To convert, can't you just export from STS as Akai and then load that into Battery, or doesn't that work properly?King of Snake wrote:
I copied the settings as well as I could from the STS programs. The kit includes the second snare, just use drag and drop with "all but midi" selected to swap the cells of snare 1 with those of snare 2
Royston
- ChrisWerner
Heh, I never though of that (must be because I've never really used the STS or worked with akai programs before). Perhaps it works, I'll try it out.On 2004-07-19 04:09, Counterparts wrote:To convert, can't you just export from STS as Akai and then load that into Battery, or doesn't that work properly?King of Snake wrote:
Royston
- Ben Walker
I know, isn't that annoying - same with Kontakt. All those lovely Akai samples, and I can't play them through Kontakt or Battery.On 2004-07-19 07:35, King of Snake wrote:
well, it seems Battery can only import Akai from cd-rom.![]()
At least it asks for a cd when you select "import akai" and it doesn't give you the option to browse your disks.
How 'bout CDXTract?On 2004-07-19 08:27, Ben Walker wrote:I know, isn't that annoying - same with Kontakt. All those lovely Akai samples, and I can't play them through Kontakt or Battery.On 2004-07-19 07:35, King of Snake wrote:
Weren't these samplese prepared for planetz members only? Maybe add the links in the private forum...
I downloaded them, but now STS starts to crash my pc upon device loading again. Will try them later then.
Thanks a lot for your work, Stige!!
- ChrisWerner
Kontakt programs are up here:
http://www.planetz.com/forums/viewtopic ... forum=13&0
- John Cooper
- Moderator
and here are the Battery kits.
Enjoy!
<font size=-1>[ This Message was edited by: King of Snake on 2004-07-20 08:45 ]</font>
Enjoy!
- Gordon Gekko
Spoimala, as long as you keep the STS programs in the same folder with the samples, they should load fine. I've moved those folders all over my h/d and they load fine, so the paths shouldn't be absolute.
Low memory sounds new to me though, I suppose you have at least 512MB? Anyway, if you load only one program, there shouldn't be much requirement for memory. It might be related to something else. Are you using windows XP?
