Cure to midi latency while recording in SX
Wired
latency
i use external clock thru spdif instead of cw as master, is that an issue for midi always recording too late?, ...i am sending midi via a mo6 and the midi is all late , all of the time, ...it doesn't matter if i use master or slave, same result, ..do you have that ignorefilter, i don't have it in my nuendo
Plato
tomylee
in my case, the midi notes are coming to soon, but only about a little more than half of a 64th note at 129bpm - not much, and I found out, thats because I do monitoring through a convertor, do, AD and DA is making some latency, probably scope few, too - if I monitor my synth with headphones from its outputs, then I have no midi latency at all - so what I need would be a feature, with what I could put some playback latency, that my metronome click and everything else is being played later by the amount that the ADDA conversions take!
Does that exist?
tom
Does that exist?
tom
