sx and windows hanging
fidox
Post by fidox »
hi !
well, i'm not 100% if in your case other mobo will solve the prob., in mine it has...
about sts sampler, i have it installed, but didn't use it much so far, but i can try next time :smile:
have nice time
that motherboard should be great!
use asio drivers. go to start/programs/accessories/system tools/system information/hardware resources/conflicts-sharing and tell me if any irqs are being shared with the scope card.
<font size=-1>[ This Message was edited by: garyb on 2006-05-08 09:43 ]</font>
gustav
Post by gustav »
I was using asio1 64bits, I tried asio2 64bits some days ago
scopesrb (PCI1, IRQ 21)
pulsar2 (PCI2, IRQ 22)
ON irq22 I have also INTEL(R) 82801 GB ULTRA ATA STORAGE CONTROLLERS
_______________________________________
our music at http://algufr.bandcamp.com
and at http://alg95.bandcamp.com
more music at http://hurpasard.free.fr/index_en.html
bingo.
the card on irq 22 will have to move to a different slot. also, the card in slot#1 is really close to the graphics card. there may be a heat issue.
did you check for conflicts in the spot i sent you to? if not plese double check there.
also, asio2 64 is NOT 64bit. it is 16 or 24 bit, but 64 CHANNELS. the other asio drivers are 32 channels max.
also, i suspect there may be a midi feedback loop in the way that you have wired the sts with cubase....
<font size=-1>[ This Message was edited by: garyb on 2006-05-08 10:13 ]</font>
gustav
Post by gustav »
Ok I will move the card on PCI2 to PCI3 (I will try I don't know if there will be enough place)
By spot do you mean the systeminformation thing ? Then Yes I checked it and the irq22 is there at conflicts-sharing ...
for the asio : Oh I was not very precise when I wrote the post - sorry : I normally was using asio1-Flt 64 and some days ago asio2-Flt 64. Thanks for the clarification !
I will create a very simple sfp project containing the minimum to reproduce the error ...
PS : I just saw that there is an update of the bios - I will flash the bios too
thank you for your help !
<a href="http://hurpasard.free.fr"> my music </a>
<a href="http://peinturesurlenet.free.fr"> my paintings </a>
<font size=-1>[ This Message was edited by: gustav on 2006-05-08 11:02 ]</font>
Shroomz~>
Post by Shroomz~> »
Hi Gustav, you should probably only flash your bios if you need any of the updates included in the new version, otherwise it may not help at all !
cheers
cortone
Post by cortone »
Scopers,
I am having similar problems to gustav. My setup is a bit different, I have a Pulsar2 card in Slot2, and a ScopePro in Slot3 (the slot furthest from the video card). I am able to get 13 Masterverbs (error on the 14th). I have abandoned the creamware midi ports due to crashing the buffers and am using a Novation Remote49 via it's USB interface, and SX3 3.1 (the latest).
My system freezes while I play a fairly simple project (1-2 audio tracks, 3-5 midi tracks). It lasts longer if I ditch the sampler from the project (I use this as a drumkit), but will still freeze during simple editing and switching between Scope and SX. I sometimes get a "Lost communication with..." error rather than a freeze.
I have an Intel 820 processor and 2/512MB Corsair memory. I have tried all the tweaks recommended at the musicxp site. USB2 is disabled, HT is off, but APIC is on. I'd hate to have to resort to StandardPC, especially since many people are having great success with this set up.
Here are the details from the conflicts/irqs:
IRQ 0 System timer OK
IRQ 1 Standard 101/102-Key or Microsoft Natural PS/2 Keyboard OK
IRQ 8 System CMOS/real time clock OK
IRQ 9 Microsoft ACPI-Compliant System OK
IRQ 12 Microsoft PS/2 Mouse OK
IRQ 13 Numeric data processor OK
IRQ 14 Primary IDE Channel OK
IRQ 15 Secondary IDE Channel OK
IRQ 16 Intel(R) 955X PCI Express Root Port - 2775 OK
IRQ 16 SAPPHIRE RADEON X300SE OK
IRQ 16 Intel(R) 82801GB PCI Express Root Port - 27D0 OK
IRQ 17 Intel(R) 82801GB USB Universal Host Controller - 27C9 OK
IRQ 20 Intel(R) 82801GB USB Universal Host Controller - 27C8 OK
IRQ 21 Marvell Yukon 88E8001/8003/8010 PCI Gigabit Ethernet Controller OK
IRQ 22 Creamware Pulsar2 OK
IRQ 23 Creamware Scope OK
IRQ 23 Intel(R) 82801GB Serial ATA Storage Controllers - 27C0 OK
I/O Port 0x0000E000-0x0000EFFF Intel(R) 955X PCI Express Root Port - 2775
I/O Port 0x0000E000-0x0000EFFF SAPPHIRE RADEON X300SE
Memory Address 0xA0000-0xBFFFF PCI bus
Memory Address 0xA0000-0xBFFFF Intel(R) 955X PCI Express Root Port - 2775
Memory Address 0xA0000-0xBFFFF SAPPHIRE RADEON X300SE
I/O Port 0x000003B0-0x000003BB Intel(R) 955X PCI Express Root Port - 2775
I/O Port 0x000003B0-0x000003BB SAPPHIRE RADEON X300SE
Are the shared devices on irq16 likely to be a problem? It sometimes seems to freeze as a result of app switching or mouse actions, but I have seen it freeze while just playing back. I had thought that the conflict on irq23 was okay based on garyb's reports of a system he built for another user, but I may have misunderstood. I notice that gustav is having a conflict on irq22, although I though that the board defaulted to irq23 for the SATA drives. I haven't tried switching the cards due to the proximity of the video card to slot1, and the length of my ScopePro card for Slot2 (SATA connectors). Is this my only option?
It would be great if AndreD could include his BIOS settings and other tweaks since he has a lot of experience with this board.
Thanks,
Cory
i would suspect a midi feedback loop or active sensing. usb2 should be ok. maybe a couple of midi monitors will give you some indication. try a midi monitor on the scope midi source first(from the controller)is it streaming active sensing and/or mid clock just sitting there idling?
what is being transmitted from the sequencer? is there a loop from the sts back to the seq?
gustav
Post by gustav »
just a question on how to procede when moving a scope card to another slot :
on reboot the system asks for new drivers - ok.
and then : is a new cw install is needed.
I'm asking because yesterday I moved the pulsar2 of slot PCI2 to slot PCI3. and then I got only "Lost communication with..." messages ...
Shroomz~>
Post by Shroomz~> »
make sure that screwing the card's backplane I/O plate into place hasn't forced the card to pop back out of the PCI slot slightly at the opposite end from the I/O plate, as that is very common.
cortone
Post by cortone »
garyb,
I'll have to check again, but I've taken great pains to make sure there are no midi feedback loops, and to remove any path for active sensing into Scope. I thought that most of the Scope midi problems related to the physical midi connectors, which I no longer use. I'll re-check tonight, if my 1-yr-old permits!
Are the shared irqs on my system okay? Any ideas on BIOS setup?
shroomz,
I had noticed the connection problem as I built my system, but thought that I had seated the card correctly. I'll check that too.
Thanks,
Cory
gustav
Post by gustav »
so here : this was in the system information :
Port E/S 0x00000000-0x00000CF7 Bus PCI
Port E/S 0x00000000-0x00000CF7 Contrôleur d'accès direct en mémoire
IRQ 20 Intel(R) 82801GB USB2 Enhanced Host Controller - 27CC
Port E/S 0x000003C0-0x000003DF Intel(R) 955X PCI Express Root Port - 2775
Port E/S 0x000003C0-0x000003DF Matrox Parhelia APVe
IRQ 22 Intel(R) 82801GB Ultra ATA Storage Controllers - 27DF
Adresse mémoire 0xE8000000-0xEFFFFFFF Intel(R) 955X PCI Express Root Port - 2775
Adresse mémoire 0xE8000000-0xEFFFFFFF Matrox Parhelia APVe
Port E/S 0x00000400-0x0000041F Ressources de la carte mère
Port E/S 0x00000400-0x0000041F Intel(R) 82801GB SMBus Controller - 27DA
IRQ 16 Matrox Parhelia APVe
IRQ 16 Intel(R) 82801GB PCI Express Root Port - 27E0
IRQ 16 Intel(R) PRO/1000 PM Network Connection
IRQ 19 Intel(R) 82801GB USB Universal Host Controller - 27CB
IRQ 19 ITE IT8211 ATA/ATAPI Controller
Adresse mémoire 0xA0000-0xBFFFF Bus PCI
Adresse mémoire 0xA0000-0xBFFFF Intel(R) 955X PCI Express Root Port - 2775
Adresse mémoire 0xA0000-0xBFFFF Matrox Parhelia APVe
Port E/S 0x000003B0-0x000003BB Intel(R) 955X PCI Express Root Port - 2775
Port E/S 0x000003B0-0x000003BB Matrox Parhelia APVe
I have a lot more conflicts as you, Cortone :
can you tell me what did you exactly disable in the bios ?
<font size=-1>[ This Message was edited by: gustav on 2006-05-10 00:32 ]</font>
disable any port/function that you don't need.
another slot might be better, but other than the ata controller and scope sharing an irq, there's no problem. many devices CAN share, scope cannot(with a few exceptions).
gustav
Post by gustav »
Let me resume all my configuration :
HARDWARE :
asus p5wd2 premium
corsair 4 GO Ram
intel P4 830 3.0 GHz
matrox perhelia
I tried 3 different disk configurations :
1 pata (system) & 2 sata raid0 (music) (bios : raid)
1 pata (system) & 2 sata (music) (bios : standard IDE)
1 sata (system) & 1 sata (music) (bios : standard IDE)
cw : scopesrb (PCI1, IRQ 21), pulsar2 (PCI2, IRQ 22) (ON irq22 i HAVE ALSO iNTEL5r° 82801 gb Ultra ata ATORAGE CONTROLLERS)
BIOS :
IDE Configuration :
- Configure SATA as : Standard IDE
- Onboard IDE Operate mode : Enhanced Mode
-- Enhanced Mode Support On : S-ATA + P-ATA
ADVANCED :
- JuperFree Configuration
-- AI Overclocking Mode : Auto
-- Performance Mode : Auto
- LAN Cable Status
-- Post Check LAN Cable : Disabled
- USB Configuration
-- Module version 2.24.0-F4
-- USB Devices Enabled : 1 Mouse
-- USB Function : Enabled
-- Legacy USB Support : Auto
-- USB 2.0 Controller : Enabled
-- USB 2.0 Controller Mode : HiSpeed
-- BIOS EHCI Hand-Off : Disabled
- CPU Configuration
-- Intel Pentium D CPU 3.00GHz
-- Frequency 3000MHz
-- FSB Speed 800 MHz
-- Cache L1/L2/L3 : 32 KB / 2048 KB / 0KB
-- Microcode Updation : Enabled
-- Max CPUID Value Limit : Disabled
-- Execute Disable Function : Disabled
-- Enhanced C1 Control : Auto
-- CPU Internal Thermal Control : Auto
-- Intel SpeedStep Tech. : Disabled
- Chipset
-- All options are Auto except :
-- Configure DRAM Timing by SPD : Enabled
-- DRAM ECC Mode : Disabled
-- Boot Graph.Adapt.Prio. : PCI Express/PCI
-- High Priority Port Select : Disabled
- Onboard devices
-- All options are Diabled except :
-- Onboard PCIEX GbE LAN : Enabled
-- ITE8211F Controller : Enabled
--- Detecting Device Time : Quick Mode
- PCI/PnP
-- Plug And Play O/S : No
-- PCI Latency Timer : 64
-- Allocate IRQ to PCI VGA : Yes
-- Palette Snooping : Disabled
POWER
- Suspend Mode : Auto
- Repost Video on S3 Resume : No
- ACPI 2.0 Support : No
- ACPI APIC support : Enabled
Software :
Windows XP Home
- "Processor scheduling" options set to "Background services"
- sound : no sound
- automatic update : no
- system restore : no
SFP 4.5
Cubase sx3.1.0 build 944
<font size=-1>[ This Message was edited by: gustav on 2006-05-10 01:02 ]</font>
<font size=-1>[ This Message was edited by: gustav on 2006-05-10 01:06 ]</font>
hmm, that should work.
if you are running in acpi mode, why do you have apci2.0 disabled? you might try a ps2 mouse and keyboard. you might try changing the p2 and the srb with each other. you might try changing the pci latency timer to 96, 128 or even 32.
did you uncheck all or most of the selections in the advanced performance settings in the system dialog in the control panel? did you turn off the screensaver and and set the theme to windows classic? these things might help if you have eliminated active sensing from your controller and avoided midi loops in the use of the sts and cubase.....
gustav
Post by gustav »
I would like to reduce those sharing conflicts - some questions if somebody knows ?
I can't see what I have to desactivate here ?
My USB use : Noah, BCF2000, Cubase-key, Mouse
So perhaps I don't need the USB2 enhanced mode ?
What is this SMBus about ?
Why do I have 2 entries like this ?
not all devices have a problem with shared resources. in general, those are normal, safe allocations. the resources ARE limited, and modern motherboards have EVERYthing built into them....
gustav
Post by gustav »
apci2.0 : default was No - did not see this one - done
ps2 mouse - done
keyboard - was ok
uncheck all selections in advanced performance settings - was ok
screensaver & windows classic theme - was ok
so I will try :
changing the p2 and the srb with each other. changing the pci latency timer to 96, 128 or even 32.
gustav
Post by gustav »
... these things might help if you have eliminated active sensing from your controller and avoided midi loops in the use of the sts and cubase.....
I don't know what you mean by "your controller" - my midi data come from the cubase midi track (I verified : there are only note on messages)
I created a very simple project with midi seq => sts and with this project its hanging after a very variable time (not allways the same).
So if there is anything that I can do to desactivate this active sensing thing tell me how and I try.
<font size=-1>[ This Message was edited by: gustav on 2006-05-10 04:13 ]</font>
gustav
Post by gustav »
moved pulsar2 from PCI2 to PCI3
disabled LAN onboard
Sharing Sonflicts are the same as before except :
no more conflict on IRQ22
IRQ 23 Creamware Pulsar2
This 2 entries no more appear :
I tested different projects and it seem to last a little longer before freezing windows
I can't move the scope srb from PCI1 to PCI2 ... (sata ports !)
(the srb can't go to pci3 - too long because the antec180 has this floppydiskcase - can't remove it)
<font size=-1>[ This Message was edited by: gustav on 2006-05-10 04:55 ]</font>
