Whoever Buys Dynatube,Let Me Know.
virtualstudio
Post by virtualstudio »
now that I solved my problems with my system I gave it a quick try.:
DT sounds Great!!
I'll have to do some more testing.
I used to a have a outboard rocktron preamp plugged into Scope to play guitar this sounds at least as good as not better!
in other words S4L buy it you can't go wrong with this Dynatube added to your live rig
regards
katano
Post by katano »
On 2006-04-17 12:18, voidar wrote:
Cool :smile:. I guess I should try that out some time. I bet that setup would exhaust all my 12 DSP's though. But it's kind of nice to really have to work for the tones like in a traditional studio setup.
But you essentially ended up with 4 mono-channels per performance, 8 files total or? Kinda overkill :razz:. But who knows.
Dynatube is heavy on the DSP if someone out there wonders :smile:. About a stereo-instance of GraphEq per loaded device.
<font size=-1>[ This Message was edited by: voidar on 2006-04-17 12:21 ]</font>
hmm, I never mentioned about dsp usage till yet. I have a scope and a pulsar2 (a total of 20 + 1 dsp's). i guess one dynatube will use 1 or 1.5 dsp's at the max (but has to be tested again). we may could open a new thread: how many dynatubes can you load! :eek:
what do you mean with 8 files? *confused-i-am*. my little math: 4 dynatubes = 4 mono channels = 2 stereo channels = 2 guitar recording takes (cause playing two dynatubes at once)... maybe it's my bad english :smile:
however, best plug of the year!!
cheers
roman
voidar
Post by voidar »
Ah, so it's really just one take. At least the way I see it. And I mean take as in performance. At a minimum I record two performances of the same riff for L/R.
<font size=-1>[ This Message was edited by: voidar on 2006-04-17 18:00 ]</font>
katano
Post by katano »
Nooooooo :smile: two takes/performances! but with each take you play two dynatubes with different amps, makes a total of 4... hehe, must be an English problem :smile:
bosone
Post by bosone »
dynatube seems very heavy on dsp.
i have pulsar1+luna+pulsar1 srb (11 dsp). i can load 5 dynatube (on an empty project) before reaching dsp limit.
instead, vinco DT seems very light
flips
Post by flips »
How good is Dynatube compared to Celco's GAM and Speaker sim? Is Vinco nice? I really only think I need Dynatube's Marshall emulator, but all three with Vinco seems to be a nice offer?
Vinco is a vintage compressor, isn't it? I guess that means it will give a warmer sound than a plain SFP compressor? Maybe also clearer? (If I sound like a newbie, it's because I _am_ pretty new to this stuff.) :smile:
(BTW: Is this 189 euro offer only for April?)
flips
voidar
Post by voidar »
The old Vinco seemes to be modelled after the UA 1176LN "Limiting Amplifier": http://www.uaudio.com/_works/images/pro ... medium.jpg
Vinco DT seemes to be modelled after the UA LA-3A "Leveling Amplifier": http://www.uaudio.com/NewFiles/LA_3A_front.jpg
Both are supposed to be very musical/smooth sounding compressors.
katano
Post by katano »
ok, dsp usage is definitely about 2 dsp's per dynatube instance...
comparism to celmo: i tried the demo 2 years ago, so i couldn't remember well. but i didn't buy it after trying, that means: dynatube sounds way better :smile:
MD69
Post by MD69 »
4*dynatube instances * 2 DSP = a scope project for an MB sound ??? a bit expansive !!!
I think I'll finally wait for a demo version !
cheers
katano
Post by katano »
you need only one dynatube instance for the mb sound :wink:
and of course, if you have not enough dsp power, you will always be able to record the traditional way, while putting dynatube in front of recording... ok, you loose the possibility to change the guitar sound afterwards, but hey, till today, it was best practice with a real amp.
cheers
roman
<font size=-1>[ This Message was edited by: katano on 2006-04-19 00:58 ]</font>
voidar
Post by voidar »
I doubt I would ever use more than two instances of dynatube per track at a time. Perhaps three for some strange clean-gritty stuff.
Mr Arkadin
Post by Mr Arkadin »
Hhhm, got me thinking, with a few more models and the ability to have more than one amp at once... Dynatube ASB anyone?
alfonso
Post by alfonso »
It should be rackmount though!
Shroomz~>
Post by Shroomz~> »
cool idea.. It could be just another ASB series of the 4 different amp heads with built in speaker/cabinet sims. They'd need to bolt a brick to the inside to simulate the weight/build quality though .. :lol:
or how about BX-Digital ASB? mmm. Maybe not. How could they charge the same for a DSP hardware version a la ASB as they do for the SFP plug-in? :wink:
MD69
Post by MD69 »
Bought it ... and they are not yet ready to go ASB IMO.
Shroomz~>
Post by Shroomz~> »
Can you explain why you've got that opinion MD69? I want to hear lots of different feedback before considering buying. Bit worried about the 2 DSP per amp, as double what an MV pro uses seems realy heavy.
voidar
Post by voidar »
I can load six of them in a moderate project on my 12 DSP's before I get the DSP-overload message.
If they would release the current Dynatube as an ASB, I would definitely need a EQ/OD-pedal in front of it for my needs.
Mr Arkadin
Well i was thinking a bit further down the line, ie. there would more models, effects pedals, wah pedals, etc. like a Pod, but with the flexible routing of SCOPE (Pod routing is fixed). It would be rackmounted and bright red...
OK maybe not red.
voidar
Post by voidar »
Right. That could work.
And hopefully not red :razz:..
It could come with pop-on/off face-plates :wink:
MD69
Post by MD69 »
Hi Shoomz,
I think it is better that you test it yourself than rely on my evaluation: guitar sound is really subjective :wink:
if you are seeking after a "recorded wall of guitar sound", you will be able to find it. Personnaly, my sound is from clean to ... light crunch for rythmic / arpeggio and crunch for solo. In that kind of sound, dynamic response to your attack is really important. On that particular point, I find the Dynatube inferior to my POD Pro (and the POD Pro far from "the real thing"). On strong attack, Dynatube is convincing (better than a GSP 2101 for example). The clean sound is well, ... clean as expected. For me the problem is with medium attack where the transition from clean to crunch is not as coherent as Line6 and perturb my playing. This evaluation is my guitarist point of view (I play mainly jazz/blues guitar in fact), and you have to know that I am stringent on that point, far more than on replicating the exact amp signature. The sound attack/dynamic is good (except for the heavy MB preset but this can be corrected by a FT clean // MB mix as it is in the real MB Mark1 which blend a clean sound with the High gain stage).
Going ASB means that you bring something better than current contenders which are known and have identified services. On all these points they are not yet ready IMO.
cheers
