Can you believe it? Amazing, what a definition!
yes, it's automatically adjusted (stepless) from 1/30 to 1/500 of a second according to the position of the aperture ring (and of course by the amount of light...).On 2006-09-03 14:26, BingoTheClowno wrote:
...is that the entire range of exposure times available that's shown in the view?
Can you take pictures in low light with an ISO 100 at lowest speed?
The construction is ingeniously simple - the opposite of the indicator needle controls the spring mechanism of the exposure.
If there's not enough light the cam still operates at 1/30, it doesn't block the exposure - which it does if the battery is empty...
The lens is in fact a prime lens, a 40mm Zeiss Tessar, at it's time nicknamed the 'eagleeye'
Digital cameras are so much more convenient and cheaper to operate, but I can't deny the fascination of the old analogs.
Let alone the tension when the exposed film is returned and you're still uncertain what to expect...
