6db boost through sfp!
tomylee
Post by tomylee »
why? do they sound different?
I´m using the asio flt drivers now...flawlessly
tom
Mr Arkadin
Post by Mr Arkadin »
i just think the ASIO2 modules are newer than the ASIO or ASIO1, hopefully some one can explain the technical benefits as i don't know.
katano
Post by katano »
from a news page back in 2001 ;-)
ASIO2 brings what Steinberg calls Direct Monitoring and Positioning Protocol to the party. Direct Monitoring delivers low-latency monitoring by sending the audio signal from the monitored input directly back to a specified output on your audio hardware. This means the signal doesn't pass through the program, so there's virtually no latency when monitoring the audio. Positioning Protocol provides sample-accurate synchronization between Cubase VST/32 and external devices. Of course, your computer's audio interface must have an ASIO2 driver in order to take advantage of these features.
greez
Roman
... Direct Monitoring delivers low-latency monitoring by sending the audio signal from the monitored input directly back to a specified output on your audio hardware. This means the signal doesn't pass through the program ...
oops, no VSTi etc... ? :o
what a breakthrough, Tom :D
voidar
Post by voidar »
I use ASIO1 because I want to record and playback 32-bit integer. The two drivers seem to perform different. ASIO1 performing better. I don't need the features ASIO2 deliver, not when it reduces quality.
Recording 32-bit int via ASIO1 equals VDAT at 32-bit.
LHong
Post by LHong »
Mr Arkadin wrote:i just think the ASIO2 modules are newer than the ASIO or ASIO1, hopefully some one can explain the technical benefits as i don't know.
ASIO2 Has the high-light features as follows:
1> VSTi
2> MIDI Event Processing
3> Offline Processing
4> Virtual Speakers Arrangement (Surround sound))
5> Panlaw setting (V2.3)
6> Others (GUI/Editor/Automation Host <--> Plug, Etc)
Hope this helps,
LongStudios
