I want a variable action keyboard
- kensuguro
well, you're right about the weight. I don't think the specifics really matter, just the concept of being able to adjust certain things is already cool enough. Actually, take another step back. A controller wtih quality keys is already better than most of the not-so-good controllers out there. Let alone, an action modeled on the rhodes don't even exist, amidst all the physical models of rhodes.
Actually, I was thinking of tackling the weight problem by changing the distance between the center of rotation of the hammer, to the contact point with the key. It's just an idea, but I'm guessing that the distance would change the resistance.. but this is all just ideas. I think I'm going to have to go buy some materials.
My point of view on re-inventing the wheel is that every time things get re-invented, it gets better.
btw, Ken take a look at that trebuchet model
http://www.eccentricgenius.ca/Products3.htm
floating arm design would allow much easier control of the distance of weight across all the keys
just because you cannot imagine something that doesn't exclude it from reality.
Counterparts
Inertia is defined as the resistance to movement I thoughtMichu wrote:regarding electromagnets, the problem is that perceived 'weight' of keys is about inertia not resistance
It could be difficult to adjust each key so they all had the same weight though, unless the mechanism allowed for adjusting all keys at once.you'd need something like a hammer mechanism with a weight on a lever, where you could adjust position of a weight so the action would be adjusted by priciple of lever, the further the weight the heavier the action.
inertia is a resistance to acceleration/decceleration
adjusting all keys at once is doable, esp if weights would be forced into vertical or horizontal motion iso circular
and i definitely want a keyboard with bullet time for extra fast solos
Counterparts
Perhaps the key to all this is to find a keyboard which is weighted suitably for one's playing style?
I reckon a set of miniature Ohlins shock absorbers with fully adjustable preload, rebound & compression damping would be the way to go. In addition, the absorbers could be filled with a magnetorheological fluid, allowing for adjustment of the rate of suspension by the application of a magnetic field.
i can perfectly understand Ken's starting point, as action of rhodes keyboard is something special and i don't know of any master keyboard that would be weighted similarly.
I was thinking for a moment about shock absorbers, but they are designed primarily to provide resistance not to emulate inertia, but most importantly i decided that i wouldn't want anything containing liquid and possibly leaking near studio... not to mention the cost of 88 shock absorbers would be a pure outrage
