He actually would have taken me up on the offer of a trip, but I told him that mushroom season was over & that I'd have thought visiting & reading PlanetZ would be enough of a trip.kylie wrote:so, what did you have to give for trade? is there a one-legged or soulless shroomz around now? :cool:
Oscilloscope for sdk/DP
Yeah - I realised pretty much straight away.
I actually got SDK when it 1st came out and installed it then (correctly I might add) but never got beyond a quick look (I blame the 14inch monitor
 ) plus there werent that many people that had it so "community support" was a bit sparse.
I've been following the development forum since then, occasionally initially but pretty much every day these days (work can get a bit boring
With the availability of the first time use manual from shayne (great work-thanks) and the catalogue of Neutrons work (not checked these out yet, despite having got SDK installed correctly, due to the fact that I now have Shaynes doc n thought best to start at the beginning - but these will be checked out) I thought now was the time to awake the beast
Now that I have started to learn SDK with some seriousness and realising the Pandoras box I have just opened, I have updated my signature accordingly
There are known knowns. These are things we know that we know. There are known unknowns. That is to say, there are things that we know we don't know. But there are also unknown unknowns. These are things we don't know we don't know.
						btw, you can fix the issues of checking out Neutron's projects in sdk 4.0 simply by loading them & re-saving them from the sdk. You might have to use the open project & 'all files' option when re-opening them though, but I can't remember now as it's been ages since we took a quick look at them. Anyway, it is possible to check them out without the crashes & other problems.
						Re:
This link doesn't work.Shroomz~> wrote:oscilloSCOPE for modular ...also works in SDK
http://www.planetz.com/phpBB2/viewtopic.php?t=23657
Could you help me out here Shroomz~> please?
Eric.
Your mouse has moved. Windows must be restarted for these settings to take effect.
Eric Northwood - Data Recovery Specialist
Re: Oscilloscope for sdk/DP
I believe i still have the original scope DP cd around somewhere. if i can find it i will have a look.
or you can run winamp in "input" mode and use something like this
http://universal-software-oscilloscope- ... chive.org/
Thanks.Neutron wrote:I believe i still have the original scope DP cd around somewhere. if i can find it i will have a look.
Is this the one mentioned above?
Eric.
really i cant remember I think i tried it once. I just use a hardware scope. i need it for other things anyways.
Ok so no osilloscope links for the rest of us .... ?
I have a hrdware scope but how do you connect it inside the SDK?Neutron wrote:really i cant remember I think i tried it once. I just use a hardware scope. i need it for other things anyways.
Eric.
just connect it to an extra pair of outputs, i usually build devices with extra test point outputs i can connect the scope to to have a look at whats going on, and just delete them later on.
as for cables i just used some coax cable and put 1/4 inch jacks on one end, and connect them to the a16 ultra.
Thanks, Neutron,
I'll give it a try.
Eric.
							I'll give it a try.
Eric.
