no, sorry. drivers don't work that way.
nobody's PCI slots are "native" anymore. unless the motherboard is socket 1155 or of that age(when native PCI was FIRST discontinued by everybody), the PCI slots with the 3rd party controllers on the current motherboards work just fine.
power consumption of scope pro and pulsar 2's
- garyb
- Moderator
acidrecords
Re: power consumption of scope pro and pulsar 2's
have to bring this thread up
has someone tested creamware cards with this one?
PCI Express base spec 1.0a compliant for up to 250MBps of available bandwidth
LP4 Power Connector Included for Universal Voltage PCI Cards (3.3V/5V)
https://www.startech.com/en-eu/cards-adapters/pex1pci1
- garyb
- Moderator
just get a motherboard with PCI slots....
the adapter probably works, though.
gonna make a custom case?
acidrecords
board with 3 pci slots is no option. i have 3 creamware cards and a motherboard with 2 pci slots + pcie slots. so one pci card will need a pci adapter.
custom case wont be a problem.
this thing with 3 additional pcie to pci adaptors would be intresting too^^ https://de.aliexpress.com/item/4000026544901.html
- valis
Latency might be an issue with that larger array. If you can ensure your primary card is in one of the PCI slots on the board (and preferably one that doesn't share resources with any demanding peripheral) then things should be fine, the slot is providing power and basic timing at that point I believe. Make sure you have your STDM cables correct too of course.
acidrecords
