Sonic Core - FIX the modular preset bug!!
Lima
Post by Lima »
roy thinnes
Post by roy thinnes »
mmh..I don't have this "bug". presets recall of mix8 is absolutely ok here.
anyway, does it occur with the mix8 module I uploaded?
and: are there specific circumstances when it occurs (BIG patch, in combination with certain other modules, only in modIII/mod2...)
in other words: is it reproducable/ does it occur everytime?
Mix8cwm.zip
(37.71 KiB) Downloaded 141 times
I downloaded this so when I get XITE-1, I can start using Modular / Flexor III in my projects. :wink:
Thanks 4 Your Work Roy.
eliam
Post by eliam »
I've had plenty of trouble with mod presets in the past, but it is the 1st time I encounter what I have here: only 1 module not recalling his presets while all the rest seems ok. In the past the banks refused to load saying "your presets are only X.XX% compatible..." and I was extra careful not to disconnect or change anything while tweaking my patches. In my last attempt I did not encounter such a behaviour. I'll try a few other things, but I spent quite some time creating the patch and tweaking all the presets, I'll invest that much more time into it... The bad thing is that it worked for a week or 2, and I put some serious work on my presets, and one day, the mixer stops recalling... Not good... I've ordered wolf's modular modules which will allow me to control non-mod synths from a fixed pitch-tracking mod patch... I'm frustrated because the flexor oscillators and filters are amazing.
Lima- I'll try your module and report, and possibly shroom's mod mixer if yours doesn't work...
À bientot
eliam
Post by eliam »
OK, I think I made a wrong assumption: I went in the mod modules files in the scope directory and replaced the old mix 8 module with the one that Ralf sent us lately, assuming it would automatically be replaced in the patch I'm working with. I just realized that it wasn't the case, so I imported the new mix 8 and reconnected everything as it was and it seems to behave normally, with the first tests I've done... So, my fingers are crossed, hopefully it is usable now...
pling
Post by pling »
good news, thanks!
