SFP5 - New features, fixes, bugs?
Re: SFP5 - New features, fixes, bugs?
Same problem like microraver
1- Minimax and minimax MK 2 show only knob when move the plug-in interface
2- STS 5000 ask for registration, when import keyfile appear: import succeed, when i clik ok the registration tool reappear..
- Mr Arkadin
i have same problem with STS5000 - also the fact that you can't get out of the registration window is very annoying - you just end up in a loop of key requests.
i assume you mean miniscope, not Minimax.
I can confirm that sts5000 bug.I never use that sampler but thanks for making me try it out......Mr Arkadin wrote:i have same problem with STS5000 - also the fact that you can't get out of the registration window is very annoying - you just end up in a loop of key requests.![]()
Yep! yes miniscope sorry
minimax work
minimax work
- Mr Arkadin
Is this a bug? No matter what i try, i cannot get the startup project to work.
You mean cant save your projekt as startup? Works here.Maybe read only thingy?Mr Arkadin wrote:Is this a bug? No matter what i try, i cannot get the startup project to work.
- Mr Arkadin
Sorry, i meant save startup project doesn't work.
- nightscope
Didn't seem to work for me either. When I saved it as "default" then it came back at startup.Mr Arkadin wrote:Sorry, i meant save startup project doesn't work.
ns
- paulrmartin
All seems well but Scope blew up when I tried to load one of the ModIII patches that comes with the install...
Will report back if it keeps doing that.
What happened to all the modular patch cables?
Maybe it just me, but I used to see all the patch cables in modular in v. 4.5.
What am I doing wrong?
Thanks,
Thanks,
The routing checkbox in the top bar of modular is checked?stebzilla wrote:What happened to all the modular patch cables?![]()
Thanks,
feature and bug:
It seems that you do not need to close cubase anymore when loading a new scope project. You just need to reset the audio device. Problem: afterwards the latency is terribly high till you re-select ASIO SCOPE.
the new SBC does not accept MIDI automation
the SL9000 has the "ratio" knob on the compressor reversed with the respect to all the other ration knobs on other devices
Yes the box is checked. I checked and unchecked. Tried several things and no cables on stock patches. I can only see new cables that I create. Any one else having this problem?sherlock wrote:The routing checkbox in the top bar of modular is checked?stebzilla wrote:What happened to all the modular patch cables?![]()
Thanks,
Cant see the patchcables also exept on flexor modulars.
one question: are warps reverb now the defult reverbs that come with bundle?
or is there another verb, if so how would you rate it?
Does V5 work with Windows 7 RC? Anyone tried that yet?
Yes there is P-100, A-100, Chorus and Inverse. Everything fully working. There is DAS RMX160 and new surround reverb.hifiboom wrote:one question: are warps reverb now the defult reverbs that come with bundle?
- Mr Arkadin
OK i can see cabling on Mod2 and Mod3 patches, but i do have one very nasty problem as before.
BUG REPORT: After adding and removing a few Mod3 patches it completely crashes Scope. This happened in 4.5 too (and 3.1c i think).
Finally got to spend a little time with v5 today.
Can confirm some of the bugs experienced by others and have found another;
BUG REPORT: Adding E-Reflector/Masterverb as an insert effect i.e. into an effect slot produces a incompatible preset dialogue box
Si
Si
