Win7 64bit problem scope 5.1 on hp xw4600
Re: Win7 64bit problem scope 5.1 on hp xw4600
fricklerderii wrote:I did the test with memtest and with memorytest in bios. Both showed no errors. anyway, there was no crash this evening. Maybe the computer has to get familiar with scopecards :roll:
With memtest+ you need to run 10-12 path to be sure your RAM is perfect,- that´s a overnite task.
Did you do that ?
fricklerderii
Post by fricklerderii »
I just did it one time. So i will start memtest again and run it for a longer time. Thanks for your advice, Budwiser
fricklerderii wrote:I just did it one time. So i will start memtest again and run it for a longer time. Thanks for your advice, Budwiser
How many RAM sticks are in your machine ?
With Memtest86+, you better test each stick separately 1st, every single one more than 10 path.
That´s a very cumbersome procedure because each test is time consuming, but otherwise you won´t find out which stick is faulty and which is not.
I´d run such test overnite during sleep, do the other next day and so on.
It makes sense to test pairs of sticks later in addition,- sometimes single sticks don´t show any issue and in a combo they do.
We did that w/ 4 identical (!) sticks in any combination and in the end we found the culprit.
Just only buying new and replacing all sticks to save time isn´t the holy grail too,- you can get issues w/ new RAM also.
fricklerderii
Ok. I start this procedure.
fricklerderii
I've got 2 sticks in the machine. they passed the test 17 times (I forgot to look after the computer... :wink: ) without any error. I think, this is not the faulty thing in the computer.
I again changed the slots for scopecards and noticed that pci ports 6 and 7 work much better than 5 and 6. It's a kind of magic...
vascomusic
Post by vascomusic »
Well, at least your memory seems to work properly :D
Let's see if slots 6+7 do the trick...
fricklerderii
Hi guys,
after a little break i will keep you up to date:
the problem is not gone so far. I now bought a second hp xw4600 for very little money. I'm waiting for shipping and then I'll do some tests and I will report the results...
fricklerderii
The Problem seemes to be solved! :D
I bought this new xw4600 and it was even a better deal than i thought before: 70€ incl. shipping, win7 home, 2 hdds, a 18" LCD monitor, 4gbram...
I installed everything and till now there was no crash at all. I'm using slots 5 and 6, whitch made such Problems on the oter board. So i think that the other mainboard is a little bit faulty.
THANK YOU ALL for your patience and your good advices!
I am so happy!!! :)
Hooray!!!
