Ill try this today.
If screensets can recall various displays this will be a game changer.
I use several merge and filters.
							Midi Filter/Router
Re: Midi Filter/Router
Seems MIDI Filters are all for MIDI Inputs.
Having Filters on Outputs would be extremely useful
Its why I use 4 and 5 Filters, mergers and monitors.
But great device and with snapshots is awesome.
Yeah each of the 4 midi inputs has two filters which can be sent to one or more of 8 outputs, so effectively you have 8 separate filterable midi outs if you want to use it that way.dawman wrote:Seems MIDI Filters are all for MIDI Inputs.
I think it will probably do all that you need in one device - filter, merge and monitor!
maus
Well golly I hope that's settled.  The Z would not be the same if Jimmy had a output filter.
Wow i just spent some times to accomodate it to my taste, that's a killer one !
Thanks a lot !
Thanks a lot !
mausmuso wrote:Yeah each of the 4 midi inputs has two filters which can be sent to one or more of 8 outputs, so effectively you have 8 separate filterable midi outs if you want to use it that way.dawman wrote:Seems MIDI Filters are all for MIDI Inputs.
maus
I shall study this even more closely then.
Can you possible add the hover for tips...?
I am serious, I over trained as a performer young, only able to understand in and out.
Ever since I started using Scope I was tripped up by source and destination, once I got it I was OK.
then I added Native and a whole other set of reverse means forward kind of shit.
thx!
You can also find midi panic button here.
simply integrate at the end of the signal chain!
+ Midi delay, if required
SR-Dly8 | Audio+Midi Helper
https://forums.scopeusers.com/viewtopic.php?t=36831
MidiDelay |MODULES #Spielraum
https://forums.scopeusers.com/viewtopic.php?p=349037#p349037
