MIDI modules
YiannisK
Re: MIDI modules
Post by YiannisK »
Thanks for the explanation but I'm still puzzled.
I understand cc assignments so what's the difference when you use midi in, on a synth and assign cc's normally under scope.
Is this for modular?
Or are these sdk modules for developers?
Sorry for my ignorance.
Marco
Re: MIDI modules
Post by Marco »
I can't understand it too, I have no idea why cv
DragonSF
Re: MIDI modules
Post by DragonSF »
CV comes from the analog world. It's just a value, to control anything instead of a pot. And yes, all these modules are for SDK.
YiannisK
Re: MIDI modules
Post by YiannisK »
Ok got it!
So with this module could you not implement something in a mixer to maybe have osc
Hui, Mackie control for scope?
Just a thought
Thanks for your efforts in keeping the platform alive with new modules, ideas.
DragonSF
Re: MIDI modules
Post by DragonSF »
YiannisK wrote:Ok got it!
Just a thought
There are no implementation limits: wherever there is a pot, you can replace it with one of the outputs. Even switches should work (think of pads).
David
Re: MIDI modules
Post by David »
Top stuff, a real boon. Thank you
Re: MIDI modules
Post by jksuperstar »
Wow, that midi in idea deserves a device, that's HUGE. No need for routing through a DAW just to get midi into scope anymore!!
DragonSF
Re: MIDI modules
Post by DragonSF »
jksuperstar wrote:Wow, that midi in idea deserves a device, that's HUGE. No need for routing through a DAW just to get midi into scope anymore!!
And no more Midi-Ox fiddling. And you can have as may MIDI-Ins as you like.
Re: MIDI modules
Post by JoPo »
DragonSF wrote:
jksuperstar wrote:Wow, DragonSF, great device!
Is there any filtering or interpolation to smooth 7bit MIDI to 32bit CV?
I can do that. But you'll always have a step, because there is no in-between state. Value is either 54 or 55, but never 54.6. On the other side, if you have an idea, I'm open to suggestions. Another way would be using 14-bit (N)RPN input. I can do that too.
But when you convert midi --> CV a lot of values can be added between 2 CC values, no ?
On the other way, I understand there is no reason... :D
Re: MIDI modules
Post by JoPo »
YiannisK wrote:Looks great!
Can you give me an example of how I would use this ?
What's it's purpose?
Sorry but I'm not familiar with CV stuff.
Just wondering if there's a use for me in my setup that I might overlook.
Thanks and keep up the great work.
Have a look at Expert sleepers Silent Way : a collection of vst's that generate audio rate modulation signal you can use inside Scope via asio. And you'll use digital CV signals ! No more midi jitter ! Amazing possibilities !
Re: MIDI modules
Post by JoPo »
Dragon !
The ext. midiinput looks really useful ! I hope you'll release it as a module...!
When I load it into my Xite, I don't have any gui ! .... .... I guess you are still working on it ...
DragonSF
Re: MIDI modules
Post by DragonSF »
JoPo wrote:Dragon !
Actually, I wanted to finish the basic stuff =SDK device)first, but in that case, I'll make module.
David
Re: MIDI modules
Post by David »
DragonSF wrote: Actually, I wanted to finish the basic stuff =SDK device)first, but in that case, I'll make module.
This is a great development, looking forward to this very useful module. Many thanks
Re: MIDI modules
Post by JoPo »
Excellent ! Computer soundcard driver are available in Scope (but doesn't always work perfectly...) and now, we are going to be able to choose any mini input directly in Scope !
:) Dragon, you're making very inovative stuff ! Great ! :)
Re: MIDI modules
Post by JoPo »
Do you think it would be possible to make a midi delay ?
I believe it doesn't exist as far as I know... Not even a modular module.
A simple device that delays all midi data on its input with time settings, of course ! :D Let's say ... Hhhh ... Up to 1s maxi !? :D
This would be useful for sending exactly the same midi CC modulation to any other parameter but with exactly 150ms delay..! 8)
It's not device ideas I miss but rather time to build them..! :roll:
DragonSF
Re: MIDI modules
Post by DragonSF »
JoPo wrote:Dragon !
Some obstacle is happeing here: As soon as I make a module or putting the device into a surface, I can't connect the MIDI out anymore (and this is not my MIDI-out, it's the MIDI-out of a standard Scope module (Fifo to MIDI).
Re: MIDI modules
Post by JoPo »
ArrrGh ! Very unfortunately, I can't help you at all about this ! :(
Maybe some other developers could ?
Or you could ask on the sdk forum, I'm not sure it's pretty busy...
So ... This message is absolutely useless for you.... Hin hin .. :D Sorry !
DragonSF
Re: MIDI modules
Post by DragonSF »
JoPo wrote:ArrrGh ! Very unfortunately, I can't help you at all about this ! :(
Thanks for recognizing my problems. I think the only one can help is Holger. But maybe I find a way around.
eric
Re: MIDI modules
Post by eric »
Dragon,
Can you include support for polyphonic aftertouch/pressure?
This is a very neglected aspect of MIDI. Especially useful with Modular.
Eric
Your mouse has moved. Windows must be restarted for these settings to take effect.
Eric Northwood - Data Recovery Specialist
DragonSF
Re: MIDI modules
Post by DragonSF »
eric wrote:Dragon,
Eric
My MIDI modules are completely transparent. I just pass everything the driver supplies to the output (with some clever buffering of course :-) ). But nothing is filtered out.
