Scope 7 and Cubase 11
fidox
Re: Scope 7 and Cubase 11
Post by fidox »
Have just tested, the same configuration works just fine also with Scope 7 version.
fidox
Post by fidox »
medway wrote: Fri Feb 05, 2021 8:29 am Hi thanks. You you mean raising the latency? I usually run on the largest setting. I think that's for ASIO only though? ASIO is working fine it's just the Windows driver I was getting dropouts from.
Interesting yes, but after i changed latency from , for example 44.1khz - 25ms, to 13ms, there was lot less dropouts with mp3, youtube, movies, they have almost gone.
fidox
Post by fidox »
Yes, soon i have changed now to 25ms, i'm hearing droputs in Youtube. Both, Scope 5 and 7.
fidox
Post by fidox »
medway wrote: Fri Feb 05, 2021 8:29 am I changed my mp3 player to WASAPI and that seems to have solved it there. Just Youtube to figure out now as there's not an option for that as far as I know.
I'm using Foobar2000 player, no problems.
medway
Post by medway »
Ah ok will try raising it up :)
medway
Post by medway »
That seems to have fixed it, thanks!
For Discord, foobar2000 and other applications that support it, WASAPI is great. It part of MS's attempt to bring their audio API's up to low latency standards, and it tends to work well enough if you're not putting too many WASAPI clients into the mix.
Also possibly of interest, you can wrap ASIO into a WASAPI layer for soundcards that don't expose the WASAPI api directly.
medway
Post by medway »
Cheers Valis, good to know.
fidox
Post by fidox »
medway wrote: Fri Feb 05, 2021 9:17 am That seems to have fixed it, thanks!
That's cool ! :)
as mentioned in the docs, the wave driver may have random dropouts.
there is an update in the pipeline. read the pdf...
