Crappy sound Cubase->Pulsar->Wavelab
ernest@303.nu
Post by ernest@303.nu »
Your routing looks ok to me (although I'd consider monitoring through a 24-bit wave-driver)
I'm glad you're getting closer - good luck!
Music Manic
Post by Music Manic »
On 2002-06-29 01:36, six_wax wrote:
the synths just sounded tinny whne recorded and burned. Things sounded ok prior to tracking into the VST sound engine from Pulsar (going to direct to the outs), but something about those synths through those drivers into that engine made tinny and thin tone. I'nve since experimented with other sound sources (software and hardware) and not found them to be so problematic...
...totally subjective, but perhaps you're not alone...
I Don't think it's the drivers.It must be the audio engine,because I can get warm sounds on SEKD with wav drivers.
TRMP8R
Post by TRMP8R »
Just a thought: if you can get your hands on the VDAT recording package, you can record directly out of your BigMixer (or whatever) into 2-tracks of the VDAT at 32 pristine bits, all within Pulsar/SFP.
Then open up WaveLab and create an interleaved stereo WAV file from the two seperate WAV files that the VDAT created. (Heck, you can actually do this within the STS samplers within Pulsar if you really want!) Top and tail the resulting file, add your dithering and burn.
That way, there is no requirement to provide softare I/O routing between your mix and the mastering package.
In my experience, I don't like to use any form of noise-shaping in the dithering process - it can sometimes add distortion to the sibilence (listen carefully for this!), althought perhaps the Apogee encoding is a lot better? Your call.
This method should at least provide a clean artifact-free transfer from Pulsar (SFP) onto CD.
kimgr
Post by kimgr »
I can't get Wavelab to recognize 32bit files from VDAT.
Does anybody know what to update to make it happen ??? (I'm on Wavelab 4.0d and newest VDAT.)
Kim.
