j9k m2 matrix v6
IF it's a problem w the preset list cos the device has got no parameters to list, maybe just add a foney switch that can be remembered in the preset list?
fra77x
Post by fra77x »
well j9k put the matrix module in a modular III patch with for example 2 waldorf oscs 2 envs 2 lfos 2 poly filters. Then change some parameters store a preset and then change some parameters again and store a new preset. save the preset list and the modular patch with a new name. Delete the patch and reload it... It should say that there is only a percent compatible (63.7%) in my case and guess the matrix module stops to recall or to store new presets anymore.
J9k can you reproduce the problem?
<font size=-1>[ This Message was edited by: fra77x on 2002-10-09 13:19 ]</font>
j9k
Post by j9k »
the matrix was posted as as a modular 2 mdl. and I have it working with my modular 2 in sfp not dp. the message " this pacthes preset list is only xx% compatible" only happened to me once when sfp 3.1 crashed while i was saving the modular. i also do not have the modular 3 to test new modules on. so i'm not releasing any modular 3 mdls. maybe in a few months.
thanks,
j9k
fra77x
Post by fra77x »
Ok j9k thanks anyway. I'll try to use it in a mod2 patch.
olivar1
Post by olivar1 »
Anyone tried the matrix V6 ?
It's really great but once I reopen the project, the presets don't recall the settings of the matrix.
I'm using Mod3
Olivar, lui même
fra77x
Post by fra77x »
The matrix v6 works ok only in a mod2 shell...
ernest@303.nu
Post by ernest@303.nu »
thanks for this great module j9k!
roy thinnes
Post by roy thinnes »
hi j 9 k,
about a year ago you created this terrific module.1000 thanks - I think a modulaton matrix is very important to make the modular device easier to connect and even "more modular".Did you stop working on it? (I mean, fixng the preset bug)
I's a shame Creamware itself did not put this thing into the modIII.
<font size=-1>[ This Message was edited by: roy thinnes on 2003-05-12 08:34 ]</font>
