Please - Hijack this thread
BingoTheClowno
Post by BingoTheClowno »
Zer
Post by Zer »
BingoTheClowno
stardust wrote:
BingoTheClowno wrote:That's disturbing!
Isn't it disgusting even ?
It is, however I think disturbing has more weight. I wonder in what context was that picture posted?
BingoTheClowno
stardust wrote:suicide 2.0
Hate 1.0.0.1 Beta
BingoTheClowno
Zer
Post by Zer »
stardust wrote::D pubertal bachelor party ?
I'm actually 35.1 years old, so that`s just more a suggestion.
Didn`t you read the text above the picture?
If you don't the 80s cult movie Leolo - watch it - it`s definately worth it...and
I'm referring to the scene with the liver - but unfortunately didn`t find it at yt. ;)
Zer
Post by Zer »
BingoTheClowno
Zer
Post by Zer »
BingoTheClowno
BingoTheClowno
Wow, thanks for that!
Zer
Post by Zer »
Zer
Post by Zer »
BingoTheClowno
Did you read how the atomic force microscopy works? It is very interesting.
Quantummechanical tunneling-effect: When approaching two biased conductors, the current increases exponentially by a factor of 10 for each 0.1nm reduction in distance before they finally make contact.
Cross-section through tip and sample in STM (contour-lines indicate constant charge density)
Because of the sharp increase in tunneling current with decreasing distance, even tips with moderate sharpness yield atomic resolution easily, because the front atom carries the lion´s share of the tunneling current!
Operation with sub-nm amplitudes is thus only possible using very stiff cantilevers (k ≈ 1 kN/m). Traditional silicon cantilevers with such a large stiffness are usually not available, moreover they suffer from two additional disadvantages:
1. The tips of microfabricated Si cantilevers point in a [001]-crystal direction - an unfavorable orientation, see [10].
2. The eigenfrequency of Si-cantilevers varies strongly with temperature (-58 ppm/K). Oscillators with low temperature drift are important in watch technology. Today, most watches utilize quartz tuning forks as time-keeping elements.
Quartz tuning forks for watches are two coupled oscillators, housed in an evacuated metal case. Most of them come with an eigenfrequency f0 = 32 768 = 215 Hz. We build cantilevers from these tuning forks by attaching one prong to a large-mass substrate and mounting a tip to the free prong, creating the 'qPlus-Sensor' [8]. Its eigenfrequency is approximately 20 kHz (depending on the mass of the tip), and the spring constant of our favorite tuning forks (taken from Swatch-watches) is k = 1800 N/m.
The advantages offered by high-stiffness, small-amplitude FM AFM have been demonstrated by experimental imaging of single atoms with "subatomic" resolution, i.e. structures within a single atom related to the orbital charge density have been resolved.
Experimental AFM image of a single atom
http://www.physik.uni-regensburg.de/for ... xm_e.shtml
BingoTheClowno
BingoTheClowno
BingoTheClowno
Zer
Post by Zer »
Zer
Post by Zer »
BingoTheClowno
