Masterverb Test Thread
diegomaggi
Re: Masterverb Test Thread
1. Motherboard: Asus Z87-C
CPU: Intel i7 4770 @ 3.4 GHz
16 Gb Ram (1600 MHz), Win 7 64 bit, Scope 5.1
2. 2xScope 15 DSP (Z Link&Plus) + 1 Pulsar II
3. Integrated graphics on i7 CPU.
4. 10 Masterverbs Pro loaded into total empty project (11th causes PCI overflow).
i7 3.40 GHz (1150 Socket), Asus Z87-C, 32 GB RAM (1600 MHz),
Windows10, 3xScope 15 DSP (Z link & Plus) Scope 5.1
Apollo FW & Motu Fastlane
Motu DP9.04, Ableton 9.1
PIII 933, 512 MB RAM (133 MHZ), WinXP SP3, 2xPulsaII+1 Luna
Eanna
How can you tell if your boards are Mark 1 or Mark 2?
jhulk
pulsa 1 and the 15dsp cards are version 1
version 2 was the 14dsp and the pulsa 2 /luna/ luna II/ power sampler/
- Bud Weiser
For sure ?jhulk wrote:pulsa 1 and the 15dsp cards are version 1
I remember Gary said lowest possible ULLI buffer size indicates Gen 1 or Gen 2 PCI cards as well as 3 ADAT I/Os if it is a card w/ ADAT.
ULLI 13ms = Gen 1
what goes lower,- p.ex. 7ms or 4ms is Gen 2.
My PCI card is 15DSP, 2x ADAT I/O, SPDIF & analog I/Os, MIDI I/O,- and I can go down to 4ms, safety 7ms and w/ a Pentium IV northwood 2.4 / 2.66 and 2.8GHz single core processor Win XP machine ...
I tested w/ all these processors and 2 different ASUS mobos.
Is it Gen1 or Gen 2 ?
Is it a Power Pulsar or SCOPE Pro w/ classic output configuration ?
I don´t have the original box, no orig. CD or manual because this card was a gift,- so I´d like to know what it really is please.
Eanna
15 dsp scope and 6 dsp pulsar 2 here.
Low ulli available, but pci overloads common enough too when loading large devices..
Wonder if setting which is board zero in cset.ini makes any difference?
djmicron
if you can have ulli settings of under 13 [email protected] Khz using a single card, then it should be second gen.
If you have a Pulsar 2(second generation) linked to a 15 dsp scope(first gen) then you can still use lower ulli settings, but the pci bandwidth performance will be the one of first gen card.
On one of my older pc's equipped with pci cards, i have one pulsar 2 second gen and 2x15 dsp scope first gen and the masterverb test changes if i remove or replace the 2 first gen boards with something second generation, from a maximum of 9 masterverbs to a maximum of 18 masterverbs.
On another pc, i have 1 pulsar(4dsp fisrts gen), one luna2(3 dsp second gen) and one xtc(6 dsp second gen), same as above, can use lower ulli settings even on the pulsar 1, but i can load max 9 masterverbs if the pulsar one is inside.
- garyb
- Moderator
Bud Weiser wrote:For sure ?jhulk wrote:pulsa 1 and the 15dsp cards are version 1
ULLI 13ms = Gen 1
if a single card will go below 13ms @44.1k, it is gen2. early 15dsp cards were gen1, most of them came with 24ADAT i/o. later 15dsp cards were gen2, a few came with 24 ADAT i/o. if you saw both types of 15dsp cards side by side, you'd see that the gen1 card was a little different in size and shape.
all 4dsp cards were gen1.
- garyb
- Moderator
nope. the later cards handled PCI traffic better. if the older card is in the computer, it degrades performance.Eanna wrote:15 dsp scope and 6 dsp pulsar 2 here.
Eanna
Re:
Looks like I found an answer to my question..ScofieldKid wrote:This is MSI Neo2-F (Nforce3 Ultra), AMD 4000+ , Nvidia AGP 6800 Ultra, 1 Scope Pro: 9 Masterverb Pro's. This NForce3 Ultra board is performing quite nicely.
Added a Project to my Pro, so now 6+15=21 DSP and 13 Masterverb Pro's. Note: my system has more capacity when the Project is "board0", i.e. DSP's 1,2,3,4,5,6 in the DSP Load window. I would only get between 9 and 12 if the order was reversed of that. The CSET.INI trick lets you switch that fairly easily, so it's good to pay attention to that.
<font size=-1>[ This Message was edited by: ScofieldKid on 2005-12-14 03:43 ]</font>
I'll try tonight...
Eanna
Hi Gary, sorry man wasn't being cheeky! Was trawling thru earlier posts to see if my idea cropped up, didn't see your post before I posted mine..
I'll try tonight and see if there is a difference.
- garyb
- Moderator
please do. i hope it helps!
- Bud Weiser
Now, mine is Gen2 because it goes below 13ms @44.1k, has 15 DSPs and 2 ADAT I/O ports (16ADAT i/o).
What was the product/model name when the analog I/Os were cinch (unbalanced) connectors ?
PowerPulsar or SCOPE Classic or SCOPE Pro or ... ???
- garyb
- Moderator
all of the above. the i/o plates were all available as a choice. the i/o plate with RCA(cinch) and no z-link connections was called "classic20".
Eanna
So....
I've checked my cset.ini, and I was surprised to see just one board listed!
[Host-Config]
Numboards=1
Board0=Host
I don't have either of:
[board0]
or
[board1]
groups in my cset.ini.
I'm nearly sure that in my old rickety PC (pre-June this year) that my cset.ini had the board0/board1 entries... That PC was flakey, hence my 'upgrade' in June... (got a near-new Dell Precision T3500 at a good price).
I have some backups of cset.ini on this PC, and none of them mention two boards.
I'm glad to see that it appears my Pulsar2 appears to be the first one to load DSPs... In the DSP Meter, I first have 1/1 - 1/6, then 2/1 - 2/14.
But wait! 2/14?! I am quite sure that I have a 15-DSP card in there! That's confirmed by the "DSPs 21" in the DSP Meter dialog header...
So what's going on? Is the 15th DSP on those board used for some redundancy? Or some board communications? Does the fact that I've a 'redundant' 15th DSP signify that I need have a Gen-1 board in?
Note that whenever I start Scope, I get:
Sorry!
A capacity limit of your DSP cards has been reached.
The specific cause is:
DSP overload: Big modules do not fit
Followed by:
Capacity limit reached
I dismiss these dialogs, and I can continue to use Scope fine. It's a minor annoyance...
So, in keeping with the idea behind this thread, I started to add some MasterVerb devices to a project with just an Analog In, an Analog Out, and an STM 1632 in.
I got as far as 8 MasterVerb's before I got a PCI-Overflow message. I dismissed that, and added a 9th. Twice more I got the PCI-Overflow, then boom - BSOD.
(losing my post here in the process!)
I've addressed IRQ sharing in the recent past as well as I can.
So what is this test designed to achieve? What are we actually testing here? I can load Zarg synths, big ones, especially since I sorted my IRQ Sharing... My DSP Meter read about a third/two fifths when I hit the BSOD, but I can and do bring my DSP Meter to about 80% on busy projects before I get cagey. What's so special about these MasterVerbs?
(Note too that I get an Incompatible Preset File dialog when adding MasterVerb to a project - dunno why - I just dismiss it, and can continue to load presets fine from "Bank0").
So:
(1) My cset.ini unusually doesn't talk about my two cards, but Scope, when running, finds them. Maybe that's why I have to dismiss the "Big Modules Don't Fit" every time I start Scope?
(2) I am loading my 6DSP Gen2 card first, ahead of my 15DSP Gen1 (quite sure it's a Gen1 now). These two reasons mean I'm slow to mess with cset.ini.
(3) MasterVerb is a pretty poor 8 before PCI-Overflow. Adding a 9th is something I won't be doing again in a hurry...
I see dudes back in 2005 saying they're 'only' getting 14 Masterverbs. My CPU would crap all over their PC's, my graphics card would render the life out of them, my SSD would wipe the floor with their mechanical drives, I've aggressively disabled all I can in Win7 32-bit, and I have a tasty 21 (20 usable it appears) DSPs hanging on tough in there. But I'm loading 8 Masterverbs...
Do you think I should address the board0/board1 business in cset.ini?
Thanks, Eanna
[Host-Config]
Numboards=1
Board0=Host
[board0]
or
[board1]
Sorry!
Followed by:
So:
Thanks, Eanna
- garyb
- Moderator
some people are willing to go to extreme lengths to optimize for the card. that was more true in the past, when some motherboards worked and some didn't. now most motherboards except the ones from the 1155 era work. people are also not setting aside a computer just for audio and destroying all nonessential processes. in addition there were some motherboards that worked REALLY well in the past. those numbers never included 1st gen cards though.
PCI overflow is when the flow of data along the PCI bus gets so congested that it will no longer support realtime audio. the reason a masterverb is the tester is that a reverb is tens and even hundreds of thousand delay lines running from the card down the PCI bus to memory and then back to the card. this is a lot of traffic. the masterverb is a known quantity that everyone can use, so it's a good test of motherboard performance.
i never mess with the cset unless there's a really good reason. just the fact that you could go below 13ms latency @ 44.1k with two cards means that the newer card is the number one(ok, in computer talk that's number 0) card. don't change it.
is the project that has that message old, like pre v5.1? is so, i might rebuild it.
if you have a first gen card, 8 masterverbs is normal, even great. for a 2nd gen card only, 8 isn't great, but it's not bad.
yes, the 15th dsp is redundant which is why it was removed by Creamware to save money in their last days.
Eanna
As always, thanks Gary..
If reverbs round trip to memory, seems that auxiliary memory available on scope board would have been a good idea?
- garyb
- Moderator
sure, but it was VERY expensive back then and the computer had plenty of it.
as with everything in life, there was give and take in the design.
- ehasting
Just to throw in - i have the same error message (PCI error) every time i start up scope.
Two click on yes and its all fine for the rest of the session.
I have always thought its suppose to be like that
Higen
http://www.higen.org
- Bud Weiser
ahh,- o.k. ...garyb wrote:all of the above.
Then I´d call it a "SCOPE Pro Classic" because it´s a gen 2 even it has 15DSPs and vs a "SCOPE Pro Plus" (balanced analog) and "SCOPE Pro Z-Link".garyb wrote: the i/o plates were all available as a choice. the i/o plate with RCA(cinch) and no z-link connections was called "classic20".
That are the names I´ve found in a "Creamware Audio Products" PDF.
thx
- Bud Weiser
Why does or did it exist at all then ?garyb wrote: yes, the 15th dsp is redundant which is why it was removed by Creamware to save money in their last days.
Became it redundant by software changes ???
When it did nothing at all always, Creamware would have been able to save money straight from the beginning,- no ?
just curious
