Ok, I have some sort of quick and dirty beta (with ultra-ghetto-interface.)  I don't think it works right tho.  Clicking on the  little button does what was requested, i.e switches between the 4 inputs increntally (and goes back to one after reaching 4), but automating it with a MIDI knob maps the 4 possible button states to various CC values instead of having it switch only on CCval 127 (which is, if I may say so, a completely retarded way to implement MIDI.)  I can't test with a proper 0-127 gate MIDI button cuz I only have knobs here.  Can anyone test it with an actual MIDI button that only sends a gate (0 or 127)?  If it works ok, I'll expand it to 8+ channels, otherwise I'll keep fudging around.  Here's the beta if anyone wants to try it out and report on it:
edit: URL removed, see following message
Put the .dsp file in your SFPAppdsp folder and reload SFP.  Preset list is there but doesn't work yet.
<font size=-1>[ This Message was edited by: symbiote on 2005-02-18 00:30 ]</font>
						Audio switch controlled by midi
Ok try this one instead:
edit: removed url, link to proper release version below
Put the .dsp file in your DSP folder, restart SFP, right click on the "Switch" button to assign a controller number (or do it by hand if you prefer,) and you should be all set.
Not very DSP lite, but should do the job. CC value 127 to increment, the catch is that it needs to go back to a value below 127 (126 or 0 or anything in between really.) So your pedal/button/modulator needs to go to 127 when pressed, and 0 (or anything below 127 really) when released. I'm not sure what happens otherwise, it might not increment at all or it might need 2 "presses" to increment (if anyone tries, post your results.) It'll go up to input #8 then cycle back to #1.
If it works ok, I'll tidy it up a bit and do a bit of a proper release in the other forum section etc.
And if anyone is curious how I did it, it went something like:
D latch from async boolean modules -> positive edge triggered D flip flop from 2 D latches -> T flip flop from that positive edge triggered D flip flop -> 3bit ripple binary counter from 3 T flip flops -> 3 bit (0 to 7) decimal from the binary counter and some more async modules -> world domination. That (except the world domination bit, it was too DSP heavy ) plus some more simple logic served as control for the signal switches.
Really basic 101 digital async/sync logic, pulled straight out of my uni books =P. I'll probably release the latches/counter stuff as unprotected devices (if it's allowed by the licence, not sure, will probably post a blurb about it tomorrow if I'm not too phased out at work, otherwise I'll release them anyway as protected devices, with howtos to build your own or something), since it's pretty basic stuff
This can be extended to any amount of inputs (powers of 2 prefered to not waste DSP) and can be reversed (i.e. 1x8 audio switch) if it's something anyone needs. Also possibility to add gimmicks like pan and volume and goblin war machines.
If anyone with a Luna2/Scope Home could do some more precise DSP-load tests, I'd be grateful. I have to load a few to get a single tick to move on my DSP load meter, roughly you should be able to load between 3 and 5 per DSP, so not too bad.
<font size=-1>[ This Message was edited by: symbiote on 2005-02-18 23:32 ]</font>
) plus some more simple logic served as control for the signal switches.Really basic 101 digital async/sync logic, pulled straight out of my uni books =P. I'll probably release the latches/counter stuff as unprotected devices (if it's allowed by the licence, not sure, will probably post a blurb about it tomorrow if I'm not too phased out at work, otherwise I'll release them anyway as protected devices, with howtos to build your own or something), since it's pretty basic stuff
Cleaned it up and added some nonsense, here's a link to the Devices forum section thread:
http://www.planetz.com/forums/viewtopic ... &0&start=0
				omnibounce
