MUBACO V - unchanged release-version 1
Although old 5-band-versions were kind of optimized on DSP-distribution and worked beautifully on my SDK I found some phasing-issues (not on the 4-band-version) with SFP (very strange).
Martin
Martin
Great device
Thanks for the work you put into this device. MUBACOdspDIST works well here and uses slightly more DSP than MUBA_0_5c.
exactly. Now I see, that you did the same thing for your tubewarmer. I'm really wondering why there are problems when not specifying to specific DSPs but to "same DSP". I understand your solution to just bring out multiple different devs with different DSP adressing, so that one can load several devices...
O.K. got it .
Martin
O.K. got it .
Martin
Maybe we're missing something or doing something wrong, but from what I've seen here at this end, the only way to guarantee alignment of a 2nd instance of a device if it can't be loaded on the same dsp as the first instance is to put it on a set dsp (or dsps) on board0 & set it to load on the same dsp/s on board 1&2 versions of the device. Seems like a workaround rather than a solution.
well, guessing from history the system wasn't designed to be sample aligned throughout the whole project - as such it's in fact just a workaround to nail things to a certain DSP.
It would end like the Digidesign aproach and leave resources unavailable in favour to match theory specs - questionable if there's any (at least with a minimal significance) effect on 'sound' at all.
Imho it's enough to know that slight displacements can happen and pay attention to critical sections (in respective cases). If you're not aware what a 'respective case' is, you wouldn't notice anyway...
Any connector, cable or whatever capacitance or inductivity introduced somewhere in the signal flow has the very same effect - it's just a bit more difficult to measure, so only a fool would do it... the caps in 2 mixer channels can easily deviate 30%, one +15, the other -15
would you replace them by parts 10 times as expensive just to be sure ? Would you avoid cables because you don't know the individual figures for resistance, capacitance and inductivity ? Some of that even changes with the way you physically place the cable...
it's a different story with a stereo device (for example) and with multiband filters it might also be a concern (no idea about the internals here), but other than that I wouldn't waste too much effort. There are more significant influences on sound...
it sounds realy realy great.
thanks very much !!!
its an very heavy tool for work.
sometimes when i use as insert on page GLOBAL1 the TubeType-knob is hidden/go lost... is somewhere in the 0 and 1 -nirvana...
with some presets the knob is there on his place again
when i change to another preset the knob is gone...
his presence can be safed in the presets
strange...
have somebody too this problem, is it to fix?
strange...
Hi!
It is normal that the tube knob disappears, when you disable sat mode. The tube-knob is only visible when tube saturation (no. 2) is activated on global 1.
The softclip knob disappears when you disable main sat.
All tube-knobs disappear when saturation is disabled. I didn't want to leave any knobs which you can turn, but don't hear a difference in sound
B.t.w. MuBaCo is only knobs which don't change sound. It's all in your head. Shrooms graphics are hypnotising so that you will never notice, that MuBaCo has no effect at all
I will look into it again. Thanks for your feedback!!!
And never give up complaining when something is wrong. I give my best to correct!
martin
martin
- the19thbear
WOW
well. I used the mucabo today on my mix, and WOW! this is absolutly amazing! i LOVE the tube adjust for each band, I can´t tell you how long I have been waiting for a decent multiband comp for scope! ( and this one is alot more than decent!)
thank you very much!
thanks!
thanks!
is it possible at all to add a wizard function??( like optimaster)
thanks!!
thanks!
thanks!
thanks!!
Thanks!
Be carefull with presets in the old 0.8 version! use new version for presets (and TEST before serious usage!!)
There is still much work to do with thisone... but I think a wizard function exceedes my knowledge and my abilities with SDK. I love the wizard in Optimaster and any wizard I'd build would be a bad one compared to thatone... So MuBaCo has to be handcrafted
Optimaster is still the better choice for the non-tweakers&listeners.
Martin
B.T.W. With softknee turned on you have to watch input-level carefully! I had some nasty distortions yesterday feeding a very loud mix in mubaco with softknee turned on.
Martin
CM3
No news with MuBaCo, here it works just brilliant, so there could be a 1 in the version number ...
With CM3 & CM3e(asy) you can modify control signal to get an expander.
Use CM modules in Control-manip Window and you will see that you get a high reduction on main window which will release with incoming control signal...
Treshold & amount are setable.
So don't forget: For this expander the releasetime is the 'real' attack-time
Have fun!
Martin
Have fun!
Martin
- cm3.zip
- (159.27 KiB) Downloaded 295 times
