winger wrote:Well, my graphics is nothing special and the pci latency tool will not change it anyway.  My bios is very simple, and does not give me the option to change the speed.
I have tried theis acople times.  If I load my mixer project, and remove the 1 master verb in it, it runs for 2 or 3 hours and the the entire pc locks up.  Power off is the only way out.
Not sure what else I can do with this system.
The laptop is an hp pavilion dv9000 with 2 gig of memory, turion 64 (dual core) and nvida graphics.  Runing windows 7 and scope 5.
 Ok, but Nvidia graphics seem they are dedicated graphics.
 Download this tool and install it (x86 or x64 depending you OS):
http://downloads.guru3d.com/download.php?det=951
 You will see all buffer settings for your devices. If your graphics card buffer is higher than put the same value you have on your Scope card. If the graphics has a buffer too high (by default), it reserves more resources for itself.
  Another thing maybe occur is that you only put a 5V, and didn´t replace the 3V. I could be a good option to get a Picopsu not expensive on ebay and make a full power supply for all voltages, have a look:
http://www.mini-box.com/s.nl/it.A/id.417/.f
  Regarding Bios, it´s very strange you have not option about power saving options.  Look in depth.
 I can load 8 masterverbs stable, 9 little unstable. Not the best but not so bad. I have not freeze problems. I suspect is a power problem because of the 3V, maybe because your are using more than one card, and I´m using only one Scope Pro. I think the pico-psu (you must check the properly Wattage)  could convert your unit in the same as the ATX version.
