Scope 7
Planet Z Announcements
Re: Scope 7
beware of older dsp files.
it's possible that you may have overwritten new files installing old plugins(or not).
shayart
Re: Scope 7
Post by shayart »
garyb wrote:beware of older dsp files.
I downloaded from SC site The installation....And copied the files To the folders (dsp,sys,dev...) Some of them existed...I chose Replace....
I installed everything from scratch!
Including the scope v7 software
Re: Scope 7
yes, that is what i said. do NOT replace dsp files when installing optional and 3rd party plugins.
if you rerun the v7 installer, it should overwrite the files you replaced.
Re: Scope 7
Post by JoPo »
What do you mean it crashes ? When you load them or when they are part of a project you're loading ?
Here, I have project loading crashes and it's impossible to know which plugin is the cause. I rebuilded half of my project to see how it will load next time. Really boring to reload the project 6 or 7 times untill it doesn't crash.
ronnie
Re: Scope 7
Post by ronnie »
How long will the discount last for?
Re: Scope 7
right now, it's until the 12th of Dec....
Re: Scope 7
shayart wrote:Hey guys...
I installed scope v7 64 bit
The software runs nicely :)
I started to check what plugins works and what does not.....
XITE 1 scope v7 windows 8.1 64bit
MASTER IT EQ - crashes
DAS Legend - crashes
DAS C350 - crashes
Are you running the MASTER IT lite version ? http://forums.scopeusers.com/viewtopic. ... t=MASTERIT
Theres also a C350 lite addressing the same issue IIRC
It also uses a tad less DSP than the original....
Have a look in Support => User Area here for MASTER IT LITE and C350L - http://www.digitalaudiosoft.com/
faxinadu
Re: Scope 7
Post by faxinadu »
you should not have overwritten new files with older dated ones :0 i would uninstall scope 7 and re-install!
http://www.oceanswift.net
Music
shayart
Re: Scope 7
Post by shayart »
garyb wrote:yes, that is what i said. do NOT replace dsp files when installing optional and 3rd party plugins.
Okay I'll try it
shayart
Re: Scope 7
Post by shayart »
JoPo wrote:What do you mean it crashes ? When you load them or when they are part of a project you're loading ?
When i load them it crashes ! the windows crashes....
Peter4724
Re: Scope 7
Post by Peter4724 »
Me too!
W10 64 Bit
Scope v7
XITE 1
ULLI 13 ms
44.1 Khz
DAS Legend
DAS Maister it EQ
When i load them it crashes ! the windows crashes....!!!!
Peter
shayart
Re: Scope 7
Post by shayart »
i reinstall scope v7 ( no replace dsp files ...)
MASTER IT LT - works :)
DAS C350 L - works :)
The usual versions are still crashes (MASTER IT ,DAS C350 )
DAS Legend still crashes
Quantum Wave still - crashes
:cry:
Brickmaster Pro - works :)
Someone else is also checking 3rd party plugins crashes??
Ambient Source
Re: Scope 7
Post by Ambient Source »
Is it worth upgrading to Scope7 yet ?
I'm running win 7 x64
Has the Wave driver been fixed for Xite ?
Do the sequencers work ?
Do the Sample oscillators work on the Zarg synths ?
Is the new Driver better ?
Do you still need hotfix for the Xite 1D ?
When will the Samplers be fixed ?
Should I just buy now and install after then next few updates
Re: Scope 7
Post by JoPo »
Maybe it can help other users...
My project / template loads without crashing, now ! :) It was my mastering chain that made troubles. It was 1 multifx + another one inside the first. I deleted them, then put the 2 multifx in serial on the project window with the same fx processors in the chain. Now, it loads perfectly ! I'm very happy !
And now, I can say that 7.0 is much more stable, loads / exit faster, nice little correction : more than 6 "recent" files in the file menu.
Apparently, S|C is working hard for STS to work fine on 64bit os, which means certainly also all modules working with wav files ! We should have the update soon. They find back what soon means for the rest of the world... I think we can talk about a real rebirth ! :) Let's hope everything will going fine in the future.
Now, they need to COMMUNICATE ! Like adding some 7.0 presentation video on Scope Zone + several video tutorials about Scope basics : I'm afraid that now, all audio computer stuff are doing like that and all audio computer stuff users expect to watch them on the official site.
I know, I know, it takes time and it's better for S|C to spend time on development... But see Falcon UVI tutorial videos, they are not made by UVI... I guess UVI paid professionnals to produce them and the result is really good / pro / serious / makes you want to try / helps beginners to learn faster / etc...
I know, I know, paying pros is hard for S|C : They don't have a lot of money... But one should see that like a short-term (& long-term too !) investment : they will necessarily sell more hardware units & softwares (short-term) + become more known (long-term).
d9d9
Re: Scope 7
Post by d9d9 »
dante wrote:
d9d9 wrote:Did i understand it right that it's not possible to run 5 and 7 on the same machine? dont like that.....
Scope 5 and Scope 7 running on same machine fine here.
How did you manage to install both?
After trying to install 5 and 7 in two different programm folders, i cant open 5 after installing 7.
Re: Scope 7
Post by JoPo »
shayart wrote:The usual versions are still crashes (MASTER IT ,DAS C350 )
:-? It's weird ! And for Peter, it's the same ? Here, it loads correctly. I've had issues with the 1610++ that crashes Scope 5.1, here, I didn't tried it yet.
I tried DAS legend, C350 without any issue. :-?
shayart
Re: Scope 7
Post by shayart »
I definitely agree JoPo !!!
Product promotion...Tutorials videos Mostly....Some of us did it :wink:
But make it more professional.....
Or still some of us need to do some tutorial video for scope v7 ? :D :D :D
shayart
Re: Scope 7
Post by shayart »
Really weird :roll:
The question is what to do.......
tonatona
Re: Scope 7
Post by tonatona »
1. Can you cascade two Xite-1?
2. Is the ASIO driver multiclient capable?
3. Can you use the Xite-1 at 96KHz without limitations?
Re: Scope 7
Post by JoPo »
shayart wrote:Really weird :roll:
I really don't know ! I found a solution for my crashes when loading Scope project but I don't know what to do when it crashes when loading a device... Except... Avoiding to use this device... :D
Does it crash on any condition ? Even if you load it on completly empty Scope ? Nothing else but DAS legend or C350 ? In insert rack or on the project window, is it the same ?
You should make all possible tests, in different conditions, maybe, you'll end up finding a way to use them... I said ... Maybe ... Change the Scope screen mode... Hide the preset folder or file from Scope before loading the device (just by changing its name)... Are you on W 7, 8 or 10 ? 32 or 64 bits ? ULLI settings ?
I just made some Solaris testing and I can say that the improvment is big ! No pci messages with 2 voices, presets I couldn't load without limit reached messages work perfectly, now ! Excellent !
For sure S|C developers made a very good job on Scope 7.0 !
