24 Bit recording in Soundforge Problem
martone
Post by martone »
This question was posted in the past and just wanted to check if there was any new fixes for it
Hey people, I've got a pretty strange problem here. When I try to record a file at 24 bit resolution (with 24 bit wave source & dest modules loaded in SFP) Soundforge (6.b) always seems to be getting a mega-loud signal, it all the way in the red when I set monitoring on in the recording dialog, even when there's no signal at all coming from SFP. I don't have this problem using 16 bit modules.
What do you think it could be?
Stige
Post by Stige »
Try to use 32-bit mode in soundforge for recording. That actually gives you 24-bit resolution. You can convert recorded files to 24-bit later
Dave909
Post by Dave909 »
I also had this problem and found out that it's the DC adjust option in the SoundForge recording window which causes it. Just disable it and then recalibrate and it's gone, pretty weird btw.
First recording in 32 and then dithering to 24 and after that to 16 would really make the quality of the 16 bit file bad since you then need to dither 2 times.
<font size=-1>[ This Message was edited by: Dave909 on 2003-11-16 13:13 ]</font>
I think stige is saying that you shouldn't need to dither as the 32bit won't exceed 24bits of resolution with a 24bit input. The extra wordlength will just be padding.
I don't use Soundforge much anymore so I can't comment on the validity of this myself...
