2 drives or RAID?
braincell
Post by braincell »
I'm using SATA with a RAID option built into my motherboard. For doing music I wonder if it would be better or faster to use one drive for my OS and one for my audio or combine the 2 drives as a RAID level 0. I realize this would delete my drive. I would probably back up an image to CDs.
spoimala
Post by spoimala »
use two drives
Nestor
Post by Nestor »
Forget it Brain... RAID it is made for something else, most particularly for server used and the like. It is not recomended for Audio stuff or DAW, keep it simple. There are too many bad experiencies about RAID. It is not yet as reliable as you may expect it to be.
braincell
Post by braincell »
RAID has been around a very long time what are you talking about? You mean SATA RAID?
Nestor
Post by Nestor »
Yes, you're right, I was talking about SATA I should have specified it, sorry. RAID nevertheless, I've read about here and there, it is not recomended for a DAW.
braincell
Post by braincell »
Why not? You might be thinking of SCSI RAID which can slow down the PCI bus.
Gordon Gekko
Post by Gordon Gekko »
raid0 will get you going faster. But the way it works implies that you have twice the chances of losing data because a single file data is written on both drives. So if you use it, make sure you have working backups
why bother?an ide drive gives a very respectable track count.let's not be techie just for the hell of it!
braincell
Post by braincell »
RAID level 1 gives you a backup for everything. RAID level 0 is faster with each drive you add. How much faster I do not know but I know it's possible to attain speeds faster than any single hard drive. This could be very important when editing digital video. You could preview your edits full screen rather than having to deal with a teeny tiny window.
afaik commercial RAID servers use dedicated machines with a specially modified server OS (based on Linux ?), but are optimized for multi-user business storage demands (many transactions with relatively small chunks of data).
SCSI Raids were frequently used when video was encoded framewise, but then even high end drives were slower than todays standard units.
Since DVI streams compress a magnitude better I wouldn't expect a problem to play back a full-screen (with the proper decoder) from current drives.
If it doesn't work, then the source of the problem might be related to the architecture of the application providing the data.
I'm not a video pro, but that's my guess.
cheers, tom
braincell
Post by braincell »
Yes but when you compress you get lossy quality. It's okay for DVD but certainly not good enough to make a film movie.
<font size=-1>[ This Message was edited by: braincell on 2003-11-21 16:58 ]</font>
darkrezin
Post by darkrezin »
RAID0 might be okay for a dedicated data drive set which is frequently backed up (i.e. an audio or video streaming disk-set which is not used for OS/programs/etc), but it's quite different to use it as an OS and Audio setup, which is absolute insanity IMHO.
peace
regarding 'lossy' quality due to image compression :
some time ago we received several high resolution, large scale prints from images at various compression rates to decide what rate should be used for archieve in future.
5 (experienced) people looked at the pics and all agreed: it's impossible to distinguish the original from the 50% reduced one :eek:
Btw at first we assumed there was an error and they only sent one version :grin:
Imho it will be very difficult to find analog video gear with a higher signal quality than DVI equipped cameras or DVDs deliver.
If you're talking about digitizing 35mm Hollywood movies you're probably right, but on computer generated films you can yield even higher compression ratios.
dehuszar
Post by dehuszar »
I've heard of RAID being used quite well for dedicated Giga machines, and stuff like that. Technically, you COULD use it for standard audio projects, and probably boost your track count, but for SFP you'd flood your PCI bus, and lose access to ASIO tracks and/or reverbs. RAID is great, but it's a bandwidth hog. More so than SCSI.
Sam
braincell
Post by braincell »
As I understand it SATA does not put a strain on the PCI.
darkrezin
Post by darkrezin »
It depends.. sometimes Intel-based boards have an intel controller which might be routed outside of the PCI bus, but otherwise it's just a chip which sits on the PCI as far as I know.
peace
