Computers may break!
spoimala
Post by spoimala »
Luckily this didn't happen to me and my CW card machine, but I'm not very happy 'cause it happened to my mom. But it COULD have happened to me. Or YOU! And it's scary. Here's the story.
One night my mom was happily using her computer and then properly shut it down. A few hours later, electricity went away for a few hours. Nothing scary about it.
It was late night so she went to bed and in the morning the lights were blinking. Like there were many sudden breaks in power supply. Some problems with electricity network.
When the situation got normalized again, she tryed to switch on the computer and nothing happened! She checked that all cables were properly attached... and they were. But she claims to have heard some noise... and seen some small "lightnings" when she moved the cables.
She thought it's best to unplug the power and wait for technician (it's me :smile: ). And wise she was, indeed, but unfortunately too late :sad:
I uncovered the PC and immediately saw some problems with motherboard: a few components were melted! And the surface of the board was darkened here and there. "That's bad, you need a new mobo". But why's that? There must be some problems with power supply so I took it for more detailed examination. I could sense the smell of burned down electrical components..you know... and it didn't took more than a few seconds and... BAM! And lot's of smoke. "You need a new power supply, too".
Okay, I bought new ones and assembled the PC again. Switched power on and? Nothing happens. At that moment I was too busy to make further examinations and I told to bring it to service.
(Okay, this is becoming too long... I'll make it shorter)
What else were broken? Not much. Only hard disk, display adapter, processor, floppy drive and cd-drive.
The only components that survived were the cover and RAM.
What if there were a Scope card inside... ! I think it's time to buy an UPS for myself.
Neil B
Post by Neil B »
We had quite a bit of that in the UK last winter with surges from the power companies.
They paid for all the damage (computers, printers, phones etc) but as you say - data can't be compensated (more reasons to back up).
I had to rewrite a jewellery companies computer system because all the reports would only work on the old printer that had been fried.
Bad luck to your mum.
Herr Voigt
Post by Herr Voigt »
Every time when I've shut down my computer I separate it from the electricity net with a simple switcher on the multi-plug (can't find the correct word!). Moreover it helps to economise energy.
Additionally I use a cheap lightning protection box. This avoids voltage peaks.
Nestor
Post by Nestor »
I plug and unplug manually everyday. But would like to have a UPS, of course.
AudioIrony
Post by AudioIrony »
:oops:
I leave mine running 24/7 . . . might think twice about that now
put it on an ups with more wattage than you expect to use.they are cheap.do it now.
krizrox
Post by krizrox »
Even I agree with that and I don't have a UPS. I do, however, have my PC plugged into a Furman voltage regulator which gets turned off at night. I've got one of those AR1215 models which keeps the voltage between a certain range.
But a UPS is really a good idea. They don't cost much. Maybe I'll make a New Years resolution to buy one.
