Word clock clicks
kperry
Post by kperry »
I've just added a sync plate to my Pulsar 2, as everything else in the studio is synced up from a central Swissonic WD8 word clock generator. Until now, I've been syncing the Pulsar 2 using its ADAT or SPDIF input (in slave mode), with no problems.
The Pulsar 2 recognises the sync plate, and on selecting external BNC, it syncs to 44.1KHz immediately. And then proceeds to pop randomly every few seconds - classic lack of digital sync/mismatched clock rates.
Ideas anyone?
Music Manic
Post by Music Manic »
Bad cable, mismatched sample rates,no termination?
kperry
Post by kperry »
Termination is fine (or there's a problem with the sync plate, but since I'm getting perfect sync, I doubt it); sample rates are both the same (44.1KHz), and anyway, word clock should lock them if they're out very slightly...that's the point of it! Could be bad cable I guess, although I'd have thought that that would result in no sync.
kperry
Post by kperry »
Solved - bizarre though.
I ended up having to change routing from source->Dakota->Pulsar (ADAT B) to source->Pulsar (ADAT B)->Dakota. No matter what I did, ADAT B on the Pulsar would not sync properly to wordclock when connected to an ADAT out on the Dakota; yet, Pulsar ADAT A would to any output from the Dakota. Go figure.
jigger
Post by jigger »
How do you feel about the WD8 after some time of using it? I`m thinking about buying one and i wonder wether i should buy rather a nanosync ?
kperry
Post by kperry »
The WD8 works nicely - it's one of those things where it does what it says on the box and does it boringly and silently.
The Sync Plate for Pulsar is another matter - avoid like the plague.
what kind of cables do you use ?
there are the 50 Ohm and 75 Ohm (RG58 and 60 if I remember right) easy to be messed.
I remember problems with ethernet once due to the wrong cable type and also some bad connectors - they seem to be much more sensible than their robust appearance suggests :wink:
how is that stuff terminated ? a resistor on a t-connector on both ends of the chain ?
I ask because I have a sync plate and never got it to work - it's presence shows in the sample rate dialog but it doesn't react as expected.
I'd like to use it though I'm curently not in exact need to have to.
ps: I rember having read something about adat-b has sync problems opposed to adat-a, just like you observed
<font size=-1>[ This Message was edited by: astroman on 2004-06-09 16:51 ]</font>
kperry
Post by kperry »
Preoper high quality word clock cables (75ohm if memory serves me right). There are sync issues with the ADAT B output (everything else in the studio is fine) and XTC is completely usless with it.
Pete
Post by Pete »
I've had trouble getting Scope to sync with two of my synths. Couldn't get it to really work unless I ran them in to another sound card, then run that into the Scope. I don't know why that works.
I couldn't get my Kurzweil K2600xs w/the digital expansion ( optical aes/ebu )to sync, so I got a Kurz DMTI. Now it works, and I can choose either ADAT or aes/ebu. I use the sync plate, but I don't know if it's necessary.
I run my Roland S-760 w/digital spidf expansion into the DMTI, since it didn't sync w/Scope either. I tried every combo of samplerates and master-slave. Got close but no cigar.
Is there a file somewhere in Scope where there's a clock parameter to adjust?
kperry
Post by kperry »
I'm really glad (and I don't mean this nastily!) that you're having problems too: I'm currently trying to get a refund for my Sync Plate and the UK distributors (SOnic8) are saying that there is no problem with it and it must be my system: hearing someone else having very similar problems is reassuring.
I don't have any more tips unfortunately - there is a clock setting for the Scope that I'm sure you've found, but beyond that, I don't think there's anything else you can tweak.
Pete
Post by Pete »
Despite what I said, I am using the sync plate and it's been beneficial. I don't have a grip on how my system really works, just replugged until I got the best sound.
I chain together maybe my kurz DMT, ( with Roland S-760 and the Kurz keyboard AES'd into that ), a Korg Oasys in a separate computer, and a Korg mixer. Of course when I start thinking of the different ways I could be routing things, I get dizzy.
I could probably use ADAT sync for everything and not use the sync plate, but I decided to stop while everything sounds good.
