New xp sfp
Ecogen
Post by Ecogen »
Just installed xp pro, Pulsar 2 sfp 3.1c, hardware properties all working. Now iam testing windows media player and wont work due to soundcard issue- cant find audio device. P4, 256mb...Now i unable to gain access in bios due to warranty reasons, but the standard Mainboard soundcard is switch off in bios allowing communication only through sfp. Is this correct? Any other tips
The default settings should do it, you might want to review them:
Maybe the onboard card removal has left some traces. WMP uses Creamware Play/Rec# in Control Panel > Sounds and Audio Devices > Audio > Playback and Recording.
Is that Wave Source# loaded in a running, sample rate locked SFP?
Yes I'd check & make sure that your current SPF project includes a 'wave source' and is wired to the audio path.
Ecogen
Post by Ecogen »
Thanks, i did miss the the control panel. I had some major probs with drivers and xp just shuting down and restarting over and over (not from sfp). So now i went back to winMe for time being.. Got another problem with Me start up message- i/o moniter,Filter VxD.32 virtual device driver error? does anyone know whats going on here.. I tried on the net with no success
