recording question
dj_yaron
Post by dj_yaron »
hey guys. I need some suggestions on how to recored my final mix. I'm runnnig Cubase SX under SFP (no XTC). Cubase output BUS1 is connected to a couple of mastering plugins in SFP and then goes out to my analog out.
How would you re-route the audio out so you could record the final mix and monitor?
Is it a good idea to send the audio to SoundForge for recording (can I do that?), or just route it to an input bus back into Cubase ?
Please help...
Yaron Ilani Music - click here
<font size=-1>[ This Message was edited by: dj_yaron on 2004-03-05 04:16 ]</font>
bassdude
Post by bassdude »
You could send it to a wave destination module to send it to programs like SoundForge, Cool Edit, Wavelab which is what I normally do or you could route it back through ASIO Dest back into seperate tracks in Cubase SX or you could send it out via ADAT or Analog or SPDIF out to a hardware recorder. Send it where ever you like. :smile:
Submarine
Post by Submarine »
Yep!
dj_yaron
Post by dj_yaron »
Thanks!!
dj_yaron
Post by dj_yaron »
mmm... i got crackles in SoundForge while recording.. seems like latency is too low. What's your latency setting when you record ?
<font size=-1>[ This Message was edited by: dj_yaron on 2004-03-05 05:45 ]</font>
since you've mastered the track in SFP there's no need to 'monitor' the .wav data in Soundforge (in case you have this function on).
If the crackles appear without audio output in Soundforge, then there might be conflicts in disc access between the 2 apps.
I'd prefer the master data as a separate stereo track routed back into Cubase, for simplicity and resoure efficiency.
samplaire
Post by samplaire »
But be aware of signal loop! You have to route the Cubase track you record to to a pair of outs that don't collide with your recording or just mute the track and record without monitoring.
<font size=-1>[ This Message was edited by: samplaire on 2004-03-05 06:06 ]</font>
Counterparts
Post by Counterparts »
What I usually do is route the final mix into Cubase (e.g. from the output of the mastering plugins/the mixer), monitor the Cubase track that's recording the mix and send that out on an unused ASIO bus - in SFP I then route that bus to the analogue outs.
Needs a ittle bit of re-wiring and it's perhaps not the most elegant solution, but it works for me!
Royston
if you have a STM mixer in your project, use the bus routing for independent ASIO recording in Cubase.
Monitoring thru CW analog out.
This bus to ASIO routing is in my default song project.
Mixer's mix to ASIO ch1, and bus to ASIO ch2.
Nothing special, it's the way it's meant to be :smile:
Counterparts
Does that apply to the STM 1632 mixer?
I've just searched through the manual ... the only busses mentioned are the aux sends.
Also...in your setup, what's actually connected to the SFP analogue outs?
Royston
Counterparts
EDIT: double post!
(first one had password missng..?!)
<font size=-1>[ This Message was edited by: Counterparts on 2004-03-05 09:11 ]</font>
in a hurry:
STM 24/48, check the Bus page, very easy, and you can use the faders for extra volume to Cubase recording, this way leaving the volume/sends ratio in Cubase intact!
The mastermix-out of the mixer is connected to the analogue out of the Pulsar, just for monitoring.
The same mix-out is connected to ASIO1/2--->Cubase-ASIO-In1/2.
Handy for fast mixdown at the end of the day, to nail the day result.
Bus1/2 (eventualy 3/4 etc) is hooked up to ASIO3/4--->Cubase-ASIO-In 3/4 (ev. 5/6 etc) etc), for bouncing aims.
No mess this way in your project or Cubase, instand bouncing or mixing down just by activating the right ASIO ch. and in SFP a channel to the right bus!
EZ :smile:
Counterparts
hubird wrote:
STM 24/48 (snip)
Ah... :smile: I'll have to check this mixer out!
Watch out for those black slopes now...
"Bend Zee Knees!"
Royston
