<a name="planetz-file"></a><a href="http://www.celmo.com"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Price ($USD): 60<BR> <a name="planetz-tag"></a>Type: Mastering Bass Enhancer<BR> <a name="planetz-tag"></a>Related To: Mastering<BR> _____________________________________<BR><BR> SubBass Booster Pro
Static or Physio Dynamic Bass Enhancer
"INPUT" Input Volume and sensitivity Control.
"DRIVE" Controlling the Physiological response and Command signal (Default "Center" or 0 dB).
"DRIVE Fix/Physio" Enable or disable the Physiological Drive control potentiometer.
(Default"Fix").
On "Physio" position, the BassBoost is "Dynamically Level Dependant" (Less input level = More bass boost).
On "Fix" position, the Bass Boost Drive level is factory set, and not input level dependant. (take care of unwanted Overloads)
"PHASE" Switch Input Phase Inverter Control (default "Off").
"SOLO" Switch Controls SubBass only signal.
"FREQUENCY" Adjusts the SubBassBooster Frequency Range (Default "100 Hz")
"PHASE I / PHASE II Switch" Adapts and change dramatically the resulting sound of the SubBassBooster response. Try "Phase I" or "Phase II" each time you change your settings. (Default "Phase II")
"SubBassBoost Control". Controls the level of the New SubBass signal. (Default"Center")
"STAND BY / ACTIVE" Switch . To compare the signal "processed" or "unprocessed"
"Dual INPUT Stereo Vu Meters" Displays the incoming stereo audio signal level.
'Dual OUTPUT Stereo Vu Meters "Displays the SubBassBooster processed Output Stereo audio Signal level.
"DRIVE" Vu Meter. Displays the "Drive Control" signal level
"PEAK level indicators" (located underneath each Audio Vu Meter)
Displays the peak values of the incoming and outgoing audio signal levels
"PEAK LEVEL Reset button" (located between the Audio Peak Meters)
2(Stereo L+R) Inputs
2 (Stereo L+R) Outputs
1 Sub Out Which delivers the Processed Sub Signal Only
SubBassBooster Pro Can also be used as insert on any Creamware mixer or device.
Scope 3 style presets
Demo on:
<BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.planetz.com/Pulsar/files/dev ... ostPro.gif" BORDER="0">
Pro Stereo Mastering Bass Enhancer
The basis basis basis principle is the same, but the application is totally different. The results are widely enhanced and a main improvement is on the Physiological Response, variable with the signal volume.On 2004-04-15 18:55, Immanuel wrote:
Is it the old SBB circuit with more user controll, or is a new algorithm?
Yes it is.b.t.w. the one in x-machine - is it the same as the old SBB?
In X Machine, the SBB is not far from the first SBB.(with good results...)
<font size=-1>[ This Message was edited by: celmo on 2004-04-16 04:27 ]</font>
- cannonball
New version with some improvements, available on line:
<font size=-1>[ This Message was edited by: Celmo on 2004-04-17 06:25 ]</font>
