Freezing problems using Pulsar 2 on new P4 DAW
First the DAW Specifications:
Pulsar 2 on
ABIT IC7-G
P4 2.8 GHz 800 MHz
Maxtor 40 GB 7200 rpm (System disk)
Seagate 120 GB 7200 rpm (Audio disk)
512 MB RAM
GeForce 2 MX GFX Card
Cubase SX 2.0
Windows XP
Now the freezing problem.
Everytime i use the SFP ASIO drivers the computer freezes (could take 5 mins up to several hours). This problem does not occur when I'm not using ASIO drivers. Strange thing, huh... this is the strangest thing. I've never had this problem on my old PIII DAW, and I have tested to put the Pulsar card back in the old DAW to exclude the possibility that the soundcard is non functional. This sh*t is driving me nuts... please if anyone could help me regain my music creativity back. The CW folks have not replied my mail that wrote them months ago... anyone, pleaze?
thanks for a nice forum!
Pulsar 2 on
ABIT IC7-G
P4 2.8 GHz 800 MHz
512 MB RAM
Cubase SX 2.0
Windows XP
"The owls are not what they seem."
that mobo is probably fine. if the prob is midi then you may need to use a usb midi interface(steinberg midex3 is about $150 or less). you may also be able to turn *off* active sensing in your controller or you may be able to delay limit or turn off sysex as some keyboards(especially roland) can fill midi buffers on your card with lots o garbage causing freezes.
the midex3(or similar) solution is a slam dunk.
<font size=-1>[ This Message was edited by: garyb on 2004-04-16 22:33 ]</font>
Hi keyhan,
I'm having similar problems with a similar mobo (IC7-MAX3)..
I spent the last 10 days hacking everything I could think of, to no avail (yet)
That kind of problem can be very difficult to resolve, and I will just tell you what I did, it didn't work for me, maybe it will do it for you?
- Update your BIOS and drivers
- Remove ALL the other PCI cards
- In the BIOS: disable USB, hyper-threading, native audio, ethernet, ...
- Try to ensure your Pulsar card is not sharing its IRQ
- Test your RAM (I used the program from http://www.memtest86.com)
- Just an idea, I didn't try it yet: raise the ASIO latency, it should decrease the load of the pci bus
- Search planetz for other tips...
Maybe you did some of this already, good luck anyway!
Then for me, I just don't know what to do. Three weeks without music, it's becoming very frustrating!!
If you can make it work, please tell us what you did!
Hi Camed,
I've already tried the most of the things you just described, and with no good results. I've turned hyperthreading off, upgraded the BIOS, the drivers etcetera. Just havent turned the USB off and didn't checked the RAM (will try the software you wrote about immediately). I only use one PCI slot and one AGP. I didn't find any IRQ conflict in the Windows devide manager.
The thing is that I first had another DAW (P4), a Shuttle barebone system, It was the same shit there. No good results with the Shuttle at all. This thing is really killing me, same here. No music in 3 weeks.
I'll tell you as soon as I solved this problem (hopefully there must be someway to fix it).
Sincerly yours,
Keyhan
Sincerly yours,
Keyhan
Mannen!!!!On 2004-04-17 11:14, Keyhan wrote:
That means I can't use any USB device? My keyboard and mouse are both using USB![]()
Jag har skrivit en heel del post om hur USB är oanvändbar i vissa system. Jag kan inte överhuvud taget använda USB. Min DAW bara bootar om och kraschar utan förvarning.
Jag kör ett P4 system också.
My specs. (But not for long)
CPU: Intel Celeron 1,8GHz (400MHz rambus)
MOBO: MSI 845E MAX
Memory: 1GB (just installed)
HD 1: Fujitsu MPF3204AT /40Gb (Main drive)
HD 2: IC35L120AVV207-0 /115GB
(additional data storage on server)
GRAPH: Point of view Geforce4 MX 440 SE
CD-ROM/Writer: Plextor 8/4/32a
Network: Telix Pro. 2000
"Creamies" =): Pulsar2 and Powersampler2
OP: Windows XP pro
Soft's: SFP 3.1c and Cubase SX.
Additional soft: SoundForge 6.0 and Recycle 2.0
Med detta sytem funkar inte USB alls.
Men du har altså problem med asio....??!!?
Jag tror också att det kan vara länkat till både midi och USB.
M-stad saknar dig !!!
Translation
Ive written alot of post about how my DAW is being "bullied" by USB. My system crasches and reeboots without warning etc etc..
I have a P4 system also
MOBO: MSI 845E MAX
OP: Windows XP pro
With this setup i cannot use USB.
But you have a problem with ASIO....??!!?
I think this could possibly be connected to both MIDI in SX and USB related issues.
Your hometown misses you !!!
Love to you all =)
(I Praise JAH)
<font size=-1>[ This Message was edited by: Jngaelin on 2004-04-17 12:49 ]</font>
the usb dongle is no problem. the kb/mouse? maybe,but there are users with those things working.
asio is solid here with sx,sonar3 and logic 5.5.1 . if it's not an irq conflict,usb problems(kb/mouse) midi or other mobo related trouble, then it's possible you are using a third party vst plugin that has triggered the p4 normalization bug. http://www.digitalfishphones.com/main.p ... &subItem=6
but i'd still bet on the midi situation. i'd guess your controller or external sequencer spit out something your cw card hates. i'd try midi usb....
Jakob, GaryB & others,
thanks all for your kind help.
Gary, i use the same pulsar card and same external midi controllers & software as I used with my fully working PIII DAW, so I don't think thats the problem. There must be something with the new DAW system or P4 systems(?). Since I've tried the pulsar with 2 different P4 DAW systems, and with bad results I really dont know what It could be.
I've tested the RAM and it seems to work properly.
I'm so f*cking tired of hardware problems.
Sincerly yours,
Keyhan
Sincerly yours,
Keyhan
Hello old friend !!!
I quote alfonso.
Do not overlook the USB thing.
It is a known issue.
What happens exactly when your DAW freezes ?
Is there a classic "blue screen" or does screen go black or does it just freeze mouse keyboard and all ??
This info could be helpfull. Different computer glitches have...how should i put it.....different graphical "freeze modes".
yeah!
I quote alfonso.
yeah!
After you changed Keyb and Mouse connections, disable the usb controllers and ports in the device manager. If they are more than one you can try to disable all of them to see if the problem is solved, and then enable each one alternatively to see if it's one in particular, so you know wich can you use if you need usb connection.
In any case is good to keep Keyb and Mouse on ps2 inputs and disable ANYTHING you don't need.
