WaveOut Problem
DeXa
Post by DeXa »
hey... i fix the Hardware IOs problem but now i have another problem!
when the scope is ON (!) and i play wave file in winamp i get this msg.
Unsupported PCM Format (44100 hz, 16 bits per sample, 2 channels). Please change format setting in input plug-in configuration or change output device in waveout plug-in configuration.
same when the Scope shut down.
why it happend to me? =
ps.
i'm not new to pulsar. these problem start after formating my computer.
bassdude
Post by bassdude »
Is scope sample rate set to 44?
Submarine
Post by Submarine »
Check out the driver you choose in Winamp.
Choose a wave driver wich you have to put in your project.
DeXa
Post by DeXa »
Scope Samplerate set to 44.1krz
i'm not sure if it's winamp... i also don't have sound anywhere else in windows =
since you installed with a hardware problem(that's what i thought the problem was,a loose card),it makes sense that the install has poblems.start over,it'll work.
i'd try installing over the top of your current install(backing up the device folder, xtcproject and any presets etc.).more than likely the problem files will be overwritten.
if that doesn't cut it,i really would start over just to save time. it'll work....
