wave drivers dont work
fuflet
Post by fuflet »
after physically removing and putting back pulsar 2 card ,wave drivers dont seem to work anymore-media player or any software that d o n't use asio ,cant find the audio drivers.
only cubase,under asio scope drivers ,works, but seems cpu load is bigger and all system works slower.
i tried restoring the system with a ghost program ,to a stage when all worked fine , but still the same.
can it be an IRQ issue (maybe putting the card in a differnt slot?)or physical damage?
thanx in advance for any idea
system:
win xp pro clean install
pulsar 2 scope 3.1c
cubase sx 2.2
AMD 2400 + CPU
Gygabyte GA7VT600
ATI RADON 9000PRO
adaptech scsi 9120
network card
midex 8
2 ide HD
1 Scsi HD
spacef
Post by spacef »
may be try to desinstall the wave drivers, then reinstall them again. It happened to me (in a computer without CW hardware) after trying to install winamp5 : after that, no wave driver was recognized.
So go, in system properties, desisntall the drivers and reinstall them again. It should work fine again after that.
<font size=-1>[ This Message was edited by: spacef on 2004-05-22 08:51 ]</font>
Its possible that you have too many wav driver entries in your registry. I know that it would be more helpful if I could provide a link (i've had to manually remove wav & midi drivers myself before) but I'm tired atm. Sorry :smile:
here:
http://www.rme-audio.de/english/faq/10entrye.htm
if it is a dead driver issue, it's a windows issue and the link has the fix.
Thank you :smile:
I'm awake now and that's exactly the link I was thinking of.
