Routing with Adat in Scope
kas_lar
Post by kas_lar »
Hi, I'm having trouble with my setup on my brand new pulsar 1 card.
I've figured out the Scope routing with Adat and the mixer thought to Cubase Sx.
Now - How do I tell the Scope that I've connected the A16 Creamware converter box to the soundcard? Under the "settings" dialog in the Scope platform? Or maybe under the "samplerate" settings?
I've made the Pulsar the "MASTER" and the A16 box "SLAVE". Is there anyting boxes I have to check?
if you have truly set scope as master and slaved the a16 to ADAT, then you should need nothing else except adat modules in the scope environment to get sound in and out.
