Midi clock / BPM in Prodyssey
Discuss Scope XTC mode.
Small-Mindedness
Post by Small-Mindedness »
Hi
How do I adjust the midi clock / BPM in Prodyssey in XTC mode ? I need a clock frequency at 90 BPM, but I can only adjust it to 30, 60 or 140 BPM.. In the manual it is describe haw to do it, but I can’t get it adjusted in more than this tree ways..
Does anyone know how to do this ?
Small-Mindedness
I got the same problem with Prisma !
Press 'Write' on the VSTi/XTC device's track, then select the BPM Clock value and draw/set it with your mouse. Activate 'Read' and BPM will go as you want it to.
Small-Mindedness
I forgot to say that I’m using Cubase SX 2 !
I have tried the suggested solution, but it still doesn’t works ! I press write on the VSTi track (midi track in Cubase), and tried to type something in the input field, I tried to use the mouse an draw, the mouse wheel ect.. Nothing happens, beside the that I have describe in the first tropic !
VST automation doesnt work on these XTc devices? On any parameter or only on BPM? Do you find the value to automate or is it not in the list? ...
it works.
Small-Mindedness
The track BPM is set at 90 BPM. I can only set the BPM in the XTC plug-in / device to 35,60 or 140 BPM. Then the best in the plug-in i'snt follwing til BPM from the track, and it sounds wrong.. I need to readjust the in the XTC plug-in / device to 45,90 og 180 BPM ! This is what I need to adjust !
