Moderators: valis , garyb
voidar
Posts: 1264 Joined: Sun Aug 18, 2002 4:00 pm
Post
by voidar » Tue Jul 27, 2004 8:13 am
Could have 8/16 audio inserts/channels and a single midi out.
For each channel you could select what note to output. Velocity value of note would depend on the incoming signal. Perhaps a "trim" or min/max controll would be needed.
This way you would use any (hardware usually) audio source (microphone or drum pad i.e.) and whatever software multi-sampled you wish.
What do you think?
voidar
Post
by voidar » Sat Jul 31, 2004 9:23 am
No one finds this usefull? The general idea is to hook it up to STS or battery or something similar.
voidar
Post
by voidar » Thu Jan 13, 2005 1:59 pm
Please, I really need this
Posts: 8466 Joined: Fri Feb 08, 2002 4:00 pm
Post
by astroman » Thu Jan 13, 2005 2:38 pm
Voidar, if that would be easy, then it would be easy as well to generate any midi controller or event and modulate it arbitrarily.
None of that is available - you may have noticed that only transform operations of existing midi data are possible.
There's a big gap to be filled...
voidar
Post
by voidar » Thu Jan 13, 2005 3:29 pm
I see. Well, thank you for explaining. I guess it would require some new atoms, as devices like this exist in the VST and DX world.
