How to get the Optimaster into a Logic Bounce
Solo
Post by Solo »
I have tried Logic's I/O plugin to try and bring the optimaster into the signal flow so I can bounce the track within logic, without having to record the output in Logic. Can anyone help me. Thanks Greg
spoimala
Post by spoimala »
ASIO SOURCE -> OPTIMASTER -> ASIO DEST
Record the whole mixdown to another stereo track. You can't use the 'bounce' feature.
Scope plugins are exatcly like hardware units.
Solo
Post by Solo »
Thanks I can actually record the output as you suggest. Logic has an In/Out plugin that exactly addresses routing a hardware unit into the 'bounce' signal path. I did get a reply from LUG and a guy said he did it.. however when I replied to his email, it kept failing. I know it can be done, just waiting for someone to come forward . Thanks Greg
paulrmartin
Post by paulrmartin »
You need to assign the right outputs and inputs in your I/O enabler in Logic.
ASIO source will probably be something other than 1-2.
Plug the first 2 outputs from that into Opiomaster.
Route the output of Optimaster to ASIO dest. slot that are free.
Assign the slot numbers Optimaster is plugged into to your I/O enabler's inputs field.
Voilà!
Are we listening?..
samplaire
Post by samplaire »
And , of course, Logic has to be set to REALTIME bounce
Solo
Post by Solo »
I use windows, logic, I assume real time bounce is Mac.. or I just havn't seen that option before.
no, it's not a Mac specific thing.
'Regular' bounce is a process where the CPU calculates all processings (eq, compression, fx etc) along the timeline of the finished track (given all data is already recorded).
Since monitoring isn't necessary in this case, the calculations are usually faster than it needs to playback the track for listening.
It's a convenient feature, but as we all know the majority of such calculations is done with a lower quality than the DSPs in SFP provide - which relativates this advantage somehow.
Users of 'native only' systems will frequently deny this fact, but since they have no way to experience the difference they cannot really be blamed for it :wink:
Solo
Post by Solo »
Thanks, do you know what menu item has this bounce option. I've only ever just hit the 'bounce' button on the output object... and always have to hear the track as the final wave is being created. Thanks Greg
scary808
Post by scary808 »
That's funny, I thought the "offline bounce" feature was exclusive to Logic 6(Mac only)...
not funny... :oops:
in my limited audio universe I simply assumed that all sequencers with native processing have this 'feature'...
sorry for the mess, Tom
they all do ofline bounce. heck, just route the stereo bus out back in to an empty stereo track and make it easy.......(realtime bounce is in one of the menus, i'm just too lazy to search :wink: )
personally i do serious mixes to dat and then transfer back to samplitude for mastering the entire cd. for quick mixes i just connect to samplitude via 24bit wave drivers and stream in realtime.(press record in sam and play in logic or cubase. of course, with cubase i set sam priority to "above normal" in the task manager and scope priority to "low") i'm sure that wavelab will work just the same. this saves me the "export"/"import" step and feels more natural...
Solo
Post by Solo »
I hope this topic doesn't go off thread. Please I am wanting a proper solution to using Logic's I/O plugin to incorportate Creamware plugins into my final bounce. So far none of the replies have worked. I have treied the routing as suggested earlier & it ends up picking up the creamware plug but any logic plugin in the master 1-2 out 'after' the I/O plug is not registering, in fact the logic levels stop working when the I/O plug is set to on. Remember, I can record the Pulasar plug, but I miss out on the Logic plugs in the output 1-2 master, or I miss the creamware plug & get the logic one . I want both. Thanks Greg ( and NO XTC option please - just the I/O plug routing)
it works here. just make sure you don't try to use the plug with send 1/2 as that is the master bus. also, if you change your asio driver modules in scope you must restart logic.
Why use the i/o plugin when you can just route your mix to SFP for processing and back into an input for recording the stereo mix?
Solo
Post by Solo »
Simple 4 me: I can load waves & logic plugs ect into my logic master out to bounce. I simply want access to the pulasr ones : I want to use a 1 step process so I can see the final levels ect in my Logic Master out.
The Logic I/O plug allows u to include an external hardware device into your final bounce. I just want the same as Optimaseter for eg is supposedly a 'virtual harware substitute'. Thansk greg
samplaire
Post by samplaire »
Indeed, my Logic knowledge is Mac specific... However if you say you alway listen to the sound while bouncing I assume you have the'realtime' bounce mode set on. I don't know if the i/o plugin works on master busses, though. From what you say we assume you have everything routed properly in your SFP project so you can ask anybody on a serious Logic forum about your problem but you have to clarify you want to use an external device 'cos it's difficult to explain the SFP specific things to people they haven't seen the card or the soft.
paulrmartin
I answered before without testing if it worked.
Now I did and it DOES work.
In your Master output strip in Logic, Choose Stereo-Logic-Helper-I/O.
Set the Output to whatever fre output you may have in your ASIO source module. Open more outputs if necessary.
In SFP route this output to Optimaster.
Route the output of Optimaster to whatever ASIO destination that is free. Again, Open more inputs if need be.
Now Set the input of Logic's I/O to the destinations where Optimaster is. It works here.
To be fair, I did give you the plugging the other way around originally. Sorry about that :smile:
Paul R. Martin - Are we listening?
<font size=-1>[ This Message was edited by: paulrmartin on 2004-09-10 08:42 ]</font>
steffensen
Post by steffensen »
hm.. i tried this way of routing, point by point. but with the compressor instead of optimaster.. well, didnt work for me anyway.
hope everyone having fun with it tho. wish i were to. :smile:
i make $$$ with it, dependably and consistantly. fun is a by-product. :grin:
paulrmartin
Screenshots anyone?
<font size=-1>[ This Message was edited by: paulrmartin on 2004-09-10 18:05 ]</font>
