MINIMAX overload message
bronYaur
Post by bronYaur »
for me MINIMAX is unusable always get overload message,MINIMAX is a powerfull device why creamware dont fix this bug?
Also in small projet the same problem,every suggestion is appreciated
best regards
JLS
Post by JLS »
im minimax using - no problem
sfp4.0 winXpsp1
1. What is your computer's hardware configuration (motherboard make&model, cpu, ram, what other pci cards and peripherals, etc)?
2. What SFP conditions are you using it under (samplerate, ULLI latency)?
3. What is the specific message?
bronYaur
Post by bronYaur »
my setup is:
p4 2.8 northwood
1024MB Rambus pc800
MB intel850 MVR2
Powerpulsar slot PCI2 no IRQ shared
Scope SRB slot PCI 3 no IRQ shared
Pulsar II Slot PCI 4 IRQ shared with Matrox g550
Win XP pro SP1
SPF 4.0
You're not trying 96khz are you?
Plato
Post by Plato »
I've discovered Minimax causes these problems if certain other (heavy-duty) plugins are used as inserts in the STM2448 (In the same project)......it seems fine if you use routing cables instead of insert slots.
<font size=-1>[ This Message was edited by: plato on 2004-09-21 14:35 ]</font>
bronYaur
Post by bronYaur »
The message is :Unexpected DSP overload with Retry or Cancel dialog box
I use ULLI 7 ms at 44
Win Xp in standard PC mode
Using wide plans never crash or problem with Scope only MINIMAX it renders my plans unstable
<font size=-1>[ This Message was edited by: bronYaur on 2004-09-21 14:30 ]</font>
