disable acpi on hyperthread
mrvinyl
Post by mrvinyl »
Hi guys
i've just spent the last hour trawling thru forums trying to find how to disable acpi on my pc.
But I can't suss it, on my old pc I could do it in device manager, but i have a hyperthread p4 now and all it says in device manager is multiproccessor acpi.
I'm using a asus p4p800 mobo and in the bios I have some options of disaling acpi apic support and few other things like aml acpi, should I disable this?
or is there a way of doing it thru XP, or do I have to reinstall again and run it on set up :sad:
any help would be great
thanx
p4 3ghz hyperthread
p4p800 deluxe mobo
xp service pack 1
pulsar 1
sfp 4.0
Counterparts
Post by Counterparts »
I'm not sure if you can change XP post-install...one can do this on W2K, but it can lead to system instabilities.
If you wish to do this, then it's best to do it at install time.
I would like to ask, "Why do you want to install XP as a 'Standard PC'"? Are you experiencing problems?
Have a read of this article:
http://www.musicxp.net/installing_xp.php
Quote:
"In fact, installing Windows XP as a "Standard PC" on an APIC compatible computer will probably result in reduced performance and a reduction with overall reliability."
Damn straight. If your MOBO has APIC, then it is best to install XP as ACPI.
Not sure about the HT, though ... from reading many threads in this forum, it does seem somewhat problematical for little gain.
Royston
<font size=-1>[ This Message was edited by: Counterparts on 2004-09-22 08:42 ]</font>
mrvinyl
Post by mrvinyl »
hi thanx for the info, looks like I might have to re-install windows to get it into standard mode then :sad:
my reason for doing this is I have reformatted and reinstalled windows xp lots of times and everytime I use music applications my system locks up!
so I emailed creamware hq and ralf reckons I should run in standard mode
and my old flawless system used to run in standard mode and I never had any problems
maybe I will lose the benefit of Hyperthreading, but if it stops my system locking up I don't care what I have to do
cheers
Counterparts
Best of luck with the install!
Is it possible to do an 'over the top' install, changing to 'Standard PC' with XP? If so, that approach may save you some time and effort (you won't need to re-install applications).
Royston 'still refusing to install XP' :wink:
you can do it with a new install by pressing f6 when asked if you want to install third paryt scsi drivers(at the very beginning) or you can go to the device manager and on the acpi device driver info press "reinstall driver" and then "choose from a list", choosing standard pc. windows will rebuild the hal with the next restart. you can turn off ht in the bios. the loss of ht will make very little difference.
<font size=-1>[ This Message was edited by: garyb on 2004-09-22 13:59 ]</font>
Guest
Post by Guest »
don't you mean press F5 when it ask you to press F6 to install Scsi device.
thanks!
