FROM WINDOWS ME.TO WINXP. activation fail..........
okantah
Post by okantah »
Hi everyone,
Im for the time using winME. last week i desided to go winXP.there after both the scope & pulsar board refused to recognized the keys.& error codes are:found corrupted data in the product registry.
cannot start SFP.error code 0001.
I have then remove the winXP.yet with winME.the problems remains.I have than any necessary magic i know,no result.ANY HELP sugestions thanx ALL in advance
Okantah cheers
did you install the driver first?(i know, dumb question, just checking...)
did I get this correct ?
you had a working WinME installation
one day it refused to work (didn't recognize keys)
since you wanted to go to XP anyway you didn't bother about the old installation, but instead made a new XP install
this also refused to recognize the keys and came up with that 0001 error message
I'm not shure (and in fact hope to be wrong), but I've once seen a similiar message with the addition 'couldn't gain access to hardware'.
The board is hopefully 'covered' by a bios issue (irq, hidden by another slot or not plugged in correctly) - otherwise it could mean that the identifier eeprom is messed up.
The latter can only be taken care by CWA direct, it's about the worst thing that can happen to the board :sad:
but sometimes hardware just runs mad.
You should disconnect the machine from power completely (unplug the wall outlet) and wait some time.
Remove the Scope card, boot up and shut down again. Then reinstall the board.
fingers crossed and good luck, Tom
okantah
Post by okantah »
garyb & astroman thanx,Both Your reactions were precised the cause of the problems.
I guess something happen at the drivers installation!as a result registry data was infect.
I manage to send registry string to CREAMWARE to Ralf,within 15 min.my SCOPe board is back to life.Hahahahahahahahahahaha
you can smile with me now.
This is interesting question TO ALL SFPeans
or SCOPEans.
if all of us would choose to BUY minimum
2 plugins per year,direct from creamware. to increase software development,also maintamance,most important of all.
I have this ideal,b'cos most CREAMWARE BOARDS are sold on used hands bases,at the end we need services & software-update from the CREAMWARE.
What do you members think about this suggestions? What happens to me just last week has many reason for this information.
Please agreed or not your opinion can HELP us all.also big thanks CREAMWARE.
Okantah cheers
