Soundcard issue
Ecogen
Post by Ecogen »
Pulsar 2, Lately it appears on start up i have to wait 10-20 minutes until i hear small popping noises through speakers before i can use soundcard.. I have re-installed, no improvement.
blazesboylan
Post by blazesboylan »
Are you sure the problem isn't with your amplifier?
What's your setup?
Cheers,
Johann
Guest
Post by Guest »
10-20 minutes that is a very very long time for the Scope/SFP software to load.
check what is running in the background maybe you got lots loading before SFP.
check your startup and see how many programs are running in the background.
Ecogen
Post by Ecogen »
Sfp loads up on start up. Able to open and edit... The other software's display asio problems, till i hear the signal( small popping noises), then it all works. Meanwhile I swith and use a cheap soundcard while waiting till Sfp works.
Is there anything in particular should look for, that is running in task manager that may be the cause. Basic setup
what is the other software? do you set up the asio modules in scope first before opening your other applications?
wayne
Post by wayne »
I might be barking up the wrong tree, but have you tried removing the cheap soundcard all together?
yes, two asio hosts cannot exist in the same computer.
Ecogen
Post by Ecogen »
The other software's are Cubase sx 1, Flstudio.. i either use the sfp default set up or xtc mode. This problem has happen before, that was the reason i got 2nd soundcard. Sfp has been working great for many months beforehand even with 2nd soundcard.. then its seems to go a little haywire. Once a month Sfp ask me to import allkeys, which i do.. if that adds any thoughts to prob.
Studio set up
Sfp, Pulsar 2 v 4
Active monitors
16 ch behringer mixer
Access c desktop
Pcr 30 midi keyboard
<font size=-1>[ This Message was edited by: Ecogen on 2004-10-25 20:23 ]</font>
