How can i run KWCGLXT05_EZVerb.oxe
liberty
Post by liberty »
Hi
I have the file KWCGLXT05_EZVerb.oxe
i clicked on this file and install it.
after i run the SFP program, and i got message that the plugin is added to registry
but now, how can i run it? where can i fine the file which i need to run into the SFP window?
in some cases you have to restart SFP to make the new entry active (it tells you then).
According to it's name this one is probably installed under the effects menu, stereo, reverb submenu.
If you rightclick on an insert slot the effects menu should popup.
<font size=-1>[ This Message was edited by: astroman on 2004-10-22 11:25 ]</font>
wayne
Post by wayne »
also, i have found that sometimes, newly installed devices that aren't showing up in the drop-down menu can be found using the file browser.
new stuff is usually in the "plug ins" folder in the device folder.
liberty
Post by liberty »
Hello again.
Thank you all for help.
I found the new installation in c:sfpdevices*.mdl <- here :smile:
